Help! Upgraded cluster.
Wareagle32
Fairview tennessee
Upgraded to the premium cluster in my 2015 ram. Cluster came out of a 2013. Works great but I can’t reset the oil life! Please advise?
luckydog
eastern Pennsylvania
Follow the procedure in the manual- turn key to "on", slowly fully depress and release the throttle 3 times within 10 seconds, then you should get a "confirm reset" message on the cluster. Move the highlight to "yes" and acknowledge. Turn the key off for a few seconds and then turn on to confirm the reset. If this doesn't work you probably have a bad cluster.
Wareagle32
Wareagle32
Fairview tennessee
Worked perfectly! Thanks !
silver surfer
South Brunswick, NJ
Check your tpms to make sure it is functioning. There were issues reported using 2013 clusters in 2015 trucks.
