Help
JayLeonard
6.7 L Cummins
Tow truck guys and police usually have a "jimmy bar" or whatever its called to unlock the door.
tron67j
Maryland
Do you have sliding rear window? Maybe bust that piece out, but first see if you can buy replacement piece online.
KeepRight
ExFalconFxr
US
EcoDiesel
Wife locked keys in running truck. Any ideas ?
While it's prop too late... Uber, run home get the spare key?
OnStar, Unconnect - maybe they can help even without a subscription.
Flip-er
Raleigh, N.C
2013 Big Horn 4x4
Didnt think the drivers would lock with key in ignition UNLESS you locked manually by pushing down the knob.
jws123
nj
I have done this once or twice at home lucky wedged top of door open a bit used coat hanger to hit un lock button.
Joes1500
San Antonio tx
Happens in the oilfield all the time. Wedge the top of the door open a bit. Then take the antenna off , put a slight bend in it and touch the unlock button.
OCDTech
Louisiana
Think his truck is still running?
If so hes not gonna have any oil on those lifters.
RVGuy
Alberta, Canada
14 hours idling? That's about what my neighbor does every week with his command start!
Every single morning, starts it and lets it time out over and over, does this for an hour before he actually gets in the truck and leaves. He's had the truck for a couple years now, I'm just waiting for it to blow a cam.
MrHayes
MrHayes
cincinnati, ohio
2016 Big Horn 4x4
Thx for the advice gents. My wife woke me from a deep sleep about locking the Key's in the running truck. So in rage/panic I reached out to you folks here before I even went out side. Lol. I was able to gain entry to the truck by prying the top corner of passenger side door and using a piece of stout wire to press the unlock switch. Took maybe 5 minutes. I bought the truck used about a month ago and it only came with one fob and a key for the doors. All of which where on the same key chain. So I have 2 things in mind to prevent this from happening again. First buy another fob. Second I'll get a magnetic key box to hide somewhere on the truck. This whole event is not surprising to me on account of wife does this a couple of times a year every year for the last 20.lol. Anyway thanks again for your help guy's. What a great community.
jws123
nj
You can cut a reg key just to get door open i keep one in my wallet at all times lol it will set alarm off but at least if you lock yourself out your able to get back in.
Quint
Minnesota
2021 Big Horn 1500
5.7L v8 eTorque
I'm not pleased to know that it's this easy for anyone to break into our trucks. Then again, as a former tow truck driver, I remember that these stem locks are pretty easy. There should be a platform on the lock stem within the door. Bend a coat hanger into a tight "V" and then find that platform by feeling around. Once you do, lift up and that will pop up the lock.
