Rustypipes12
- Jun 16, 2022
- 28
- 7
- Location
- Buffalo, NY 14207
- 2008
- 5.7 hemi
Well , what started out as an annoyance is now a seemingly insurmountable problem. I have an '09 TRX4 that had a TIPM problem that caused a short. I found and fixed the short and went through the harness checking fuses and relays with the help of a couple ASME mechanics. I wound up replacing the PCM, ABS control module, and the TIPM in addition to the rear bulbs and sockets and brake pedal switch. I had the truck towed to a dealer to have the TIPM and ABS control flashed and an open recall fixed the the shift interlock. The service manager called and said he wasn't charging me because there was nothing they could do! They were unable to communicate with the truck. I've only got 68k miles on this. I know the TIPM was bad because my windows would roll down by themselves and the door locks acted haunted. The windows rolled down during a rainstorm and my electronic trailer brake module shorted out. I removed it and went from having a third brake light that stayed on with the key out to no brake lights at all. That was the start
