Help!!!
Goatman91
Louisiana
Ok so I was at my hunting camp yesterday and had to lock it in. It was pretty soft with some water and I had to get on it pretty hard to make it through. My svc 4wd, abs and traction control light came on. I can't notice anything not working correctly except my cruise control won't work. I unhooked the battery to try and clear the codes but they came back on right away. Is there anything I can do to avoil taking it to the dealer?
jwheeler
Washington
Knowing why those lights are on is the first step. If it is not under warranty, pull the codes and see what they are.
doz
I actually had the same issue come up except I hit a big bump (I mean deep trench). It was weird. Same behavior you are describing. It magically went away by the time I got home (3 hour trip). Still not sure what it was. No codes were left.
jwheeler
Washington
Let us know what codes you get
G
Goatman91
Louisiana
So I'm not getting any codes or at least the reader I used isn't showing any. My cruise won't still won't work and my truck won't switch into 4 lo.
jwheeler
Washington
If the light is on there are codes in the abs module. The cruise won't work if there is an abs problem. Need a different reader. You can look around and see if you can find a broken wire or sensor or something but until you pull the codes, it will kind of just be guessing.
doz
Did you try resetting? Like I stated before, this happened to me and it never came up with a code (atleast not on my Trinity, which will pull soft codes as well as hard codes).
Remove negative cable and let it sit for 30+ min. See if it goes away.
jwheeler
Washington
It likely only pulls pcm codes.
G
Goatman91
Louisiana
Ya i did reset the ecm. Lights came back on right away. I'll get a different reader tomorrow or Tuesday to read the codes. I'll let yall know what they are. Do yall know how the 4wd actuates? Is it like the IWE sy stem ford uses or is it something different? I tried to shift it into 4 hi on the fly and it shuttered and mad a slight grinding noise before it locked in?
doz
You are supposed to be able to shift on the fly but I never trust that personally.
G
Goatman91
Louisiana
I've done it before a couple times and never had a problem. I don't do it often, hardly ever actually. First time it ever did that though.
jwheeler
Washington
Don't know what IWE is. But you can shift to 4hi up to like 20mph or something like that
G
Goatman91
Louisiana
IWE is independent wheel ends. Fords 4wd system engages and disengagespecially off of vacumm. I was wondering if ram uses the same system or if it all electronic. Might give me a clue to what the issue is but I'm sure when I find out the codes that will take the guess work out.
jwheeler
Washington
It is all electronic on a 2012. Went away from the vacuum actuator a long time go.
lonewolf2873
Rochester Hills, Michigan
2014 Ram Crew Cab 4x4
I've shifted into 4wd at 45 or 50 more than once, this season alone.
I would look around actuator and be sure there is no obstruction. Then I would look at wheel ends for any debris or busted sensors.
G
Goatman91
Louisiana
The connector for the rear abs sensor is broke off. Sensor itself is intact. Do any yall know where I can get just a connetor. I called the dealer and they'll only sell me the whole harness. 300 bucks. Anyone got an idea. Website maybe?
jwheeler
Washington
Nice find. I'm sure there is somewhere online but I don't know of any place but the dealer. Call and talk to someone else or another dealer. They sell connector repair kits for almost every connector on the truck. Usually around $20.
G
Goatman91
Louisiana
I managed to fine a re pair kit and slapped it on. Problem solved. Thanks for yalls help.
Reticle918
