Helwig rear sway bar
sickboy
My truck came without a rear sway bar. i was planning on getting the Helwig one. What additional parts do i need to install it? oh yeah, it is stock height.
DavidN
Central Florida
You need the end link rods.
The Hellwig sway bar comes just with bolts and brackets.
From Hellwig Website:
Vehicles not equipped with rear sway bar requires 7961 end link kit.
S
sickboy
thanks. i saw that, but p/n 7961 doesn't come up on their site. lol.
jag1886
Boise Id Gods country
Demi 5.7 S&B CAI, flowmaster merge collector, Gibson cat back, oil catch can, 87
I think you can buy the OE ones for a lot less than $90.
VegasDragger45
I have my stock rear swaybar end links that I took off my truck. Send me a message
DailyRam
North Carolina
Not to hijack the tread, but if you are replacing a stock rear sway bar with an aftermarket one like the hellwig, there is no need to change the stock links, correct?
jettajam1
CA
2012 and 2019
With the Hellwig, that's correct, it bolts right up. Although, I'd check the bushings on your stock links and inspect for any cracking and replace as necessary.
VegasDragger45
Correct unless you have lifted the vehicle then you want the adjustable links to allow for the additional height
BlownGP
Houston/Baton Rouge
Well the Hellwigs are stronger and thicker than the stock. Is it worth probably not unless you are auto'xing the truck.
Yes it bolts in like stock. It is also adjustable too. Which a very cool feature.
