HID install question.. Daytime running lights
spencer1122
Toronto, Ontario, Canada
2017 Sport
hey guys, for those of you with daytime running lights and projector housings... is it just the turn signals that are supposed to illuminate? or are the projectors supposed to illuminate at DRLs as well?
i installed HIDs today and couldve sworn that the projectors illuminated as DRLs before but i could be mistaken. goes to say that they do not now after install
ExpressRules
Southern New Jersey
2019 Big Horn Crew Cab
I believe I have read posts in the past that said Canadian trucks have DRL's so you may be right that your truck had DRL's.
spencer1122
spencer1122
2017 Sport
I’m in Canada! I have drls but I was wondering if something from my hid install messed with my drls because all I get no when I’m in drive is the turn signals
TonyMM
2016 RAM 1500 CC 6"4 4X4
Only the turn signal as DRL!
(I have a 2016 Canadian 1500 with the projectors. And HID)
JB1
Houston, Texas
I don’t know, I’m actually not sure that the highs are susposed to illuminate. The whole reason I’m asking here.
I thought that it was just the turn signals on projector lights. Now on the non projector headlights it’s something else
spencer1122
spencer1122
2017 Sport
hey guys, have my next issue im trying to get dealt with. i think the tab on the 14 pin connector behind the headlight has broken off causing the turn signal to go out and the low beam to work intermittently . do you know if they sell a replacement connector? dont need the whole wiring harness.
i found this but its for VW's... looks pretty similar to me
https://www.ecstuning.com/.../electrical.../1j0973737/
JB1
Houston, Texas
Post a link to the HID kit you installed
Jarhead57
Santa Barbara, Ca
2015 4x4 CC Bighorn
I think highs only light up half power for DRLS on reflector lights.
adurm
FL
2015 RCSB
You can't have bixenon and do a low voltage to make drl in the same bulb. Lo and high beam are the same bulb just a matter of the internal cutoff shield dropping for the hi beam. If the connector pin is broke, you should be able to find replacement pins and make it work. Double check to make sure it's not just bent and missing the hole. JJ at retroshop might make harnesses.
spencer1122
spencer1122
2017 Sport
the low and the high are different bulbs in the projector housing,
and i broke the tab on the outside of the connector so it doesnt sit properly, need a new one or need to jimmy rig so it stays connected
adurm
FL
2015 RCSB
Sorry i thought it was all one for some reason. You should be able to have the hi beam as drl then. The projector, no.
drooler
Alberta, Canada
2015 Sport
Projector housings use the amber turn signals as DRL's- not the actual headlight bulb. High beams are strictly high beams (separate bulb system from the low beam).
As far as your pin issue- sorry can't help there.
Fpye
