How low?
trev
How low is this truck? And what size tires?
I ask because I want to get my truck as low as possible just by cutting springs, and really like the stance on this truck.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
That truck looks like it has every bit of 4-5" front drop. That is going to be very difficult to achieve with springs alone.
trev
trev
I'm thinking the body kit helps a bit. Because his tires look about the same size as mine (305/40/22) and I can only fit MAYBE 3 inches up front.
03lowram
Houston, Tx
5.7(Hemi)
4-5" up front, plus body kit. It looks to have a lot of negative camber in the front as well.
Pretty sure those tires are 285/45/22
trev
trev
Well I guess I'm gonna have to shrink my tires in 60k miles when it's time for new ones! Lol
WhiteExpress
Midland, TX
It's certainly a nice stance. I wouldn't be surprised if that was bagged in the front.
SILVER_BULLET
those are not 285/45/22 if you look at the truck from a different angle you can see that theyre smaller and you can probably get a drop close to that with springs and spindles up front and out back idk what you can do since most people only do 5 inches at the most
kcbigbadram
kansas city
HEMI
Totally off topic but does anyone know what wheels those are. They look pretty cool
justin443
Houston, TX
2010 RAM 1500 Sport 2wd
I'd say it looks like a 4/6 drop 5/7? somewhere around there, idk about bagged though
WhiteExpress
Midland, TX
I sure am liking that factory body kit too...
Just wish they integrated the front lip into a whole new cover instead of a cheesy tape on unit like they ended up with. Nothing a lot of bodywork and plasticweld can't fix. lol!
Birddog
West Palm Beach, FL
2016 Bright White 3500 Laramie 4X4 Long Bed
6.7 Cummins TD, 3.73
If you go that low cutting springs and it works you'll have a very bouncy ride. The other problem you might run into is compressing the shocks too much. They'll probably bottom out when you hit bumps in the road.
rambob
LA/MS
318 5.2l
I agree, it looks bagged, with the front camber off.
do not cut the springs for a 4" drop.
Raadz
