04fxdwgi
- Joined
- May 19, 2023
- Posts
- 1,737
- Reaction score
- 3,633
- Location
- Coastal NE North Carolina
- Ram Year
- 2016 1500 Sport
- Engine
- 5.7 Hemi
The Ram will toss a code if the humidity sensor loses comms, which mine did..I have a customer who owns a 2016 Mazda CX5. It has an auto A/C unit. She is a tad chubby! (Is that PC???)
Her A/C light would flash and the cooling of the system would diminish... not to the point of failure; just not with that "EDGE" that normally existed.
After lots of rutzafrutzing on my part, in that there really was no pathway such as a DTC or 3, I figured out that the light flashing was that the recirculation door was intermittent.
I removed the glove box and the cabin filter and observed the action of the recirc door... and, wouldn'tcha know, it worked flawlessly and the light was steady. Hmm.. I notice that the wires running to the actuator were literally no bigger than a sewing thread, and the plug was so little, that I had to use bright light and a magnifying glass to inspect the connector and drag test the pins. Never mind that I'm a old fart!
I cleaned the connector on both sides with "Deoxit", although they appeared to be clean. Problem went away. Go figure.
Perhaps this could help someone in their journeys through high tech stuff!
someone stole.
