Jimmy07
- Joined
- Feb 23, 2017
- Posts
- 3,257
- Reaction score
- 2,918
- Ram Year
- 2017
- Engine
- 6.4 Hemi
The handles are the same for the 1500s/2500,etc.
Max steel metallic driver handle- 1UJ831ARAH
Passenger handle- 1UJ881ARAH
Edit: never mind those numbers. Those are with chrome.
Here’s a VIN of a MSM sport that you can give to Benny for the rear handle part numbers- 1C6RR7MT3HS843840OK thanks - yeah for whatever reason I'm not able to locate any full body color Rear door handles in Max Steel Metallic, either 1500 or 2500. I did see "Steel" color in the 2500 rear door parts list/schematic, that might be it - I'll contact Benny at AllMoparParts and confirm.
I'm pretty sure I've seen a Max Steel Metallic with body color handles all around in a photo somewhere though so they must exist. But if not and I am mis-remembering then it's easy choice I guess to stick wtih my chrome/MSM handles after all lol.
Ok thanks - I am going to read back and work up a parts list to make sure I understand/got everything right for a self install. It's building the harnesses (and ripping apart the drivers door) that gave me pause over the auto tech kit tbh.
I personally like the look of the 4th gens with a little chrome. Without it, they look like a "base" truck to me. Chrome adds a bit of upscale look, like you spent more on your truck than the other guy
Good point - I uploaded a better pic.
Some of the Sport pics I'm seeing I'm not wild about... but they are completely devoid of chrome so that might be why.
Sticking with Chrome would be cheaper, since only two handles to buy
It shouldn't make any difference at all because before they came out with the recall I'm sure the trucks would shut off if you pushed the button and they were in gear just like they do with the standard key fobs. I think there's a code that we've missed. I pushed the button and held it. I tried everything the truck will not shut off unless it's in park. I didn't try it in neutral though.
I kind of doubt it was part of the recall. I can't see Ram or any other manufacturer releasing a vehicle that will not turn off unless it's in park.I would be interested to see if it works with people that bought the actual kit to add this on.
I kinda sorta wonder if the "fix" is actually part of the U05 recall.
