How To: Add Factory Keyless Enter N Go
whitezracer
Ripley, Tennessee
When I try to relearn the fob it says failure: fobik already learned so it seems that the hub is picking up the fob and when I check the fault codes the only thing I’m getting is the faults for the door handles and door antennas because I have not got to installing those yet.
Lawsuit11
Fort Worth, TX
But Alfa also says ignition must be in run position when running fob locate and I can’t put it in the run position.
Mine doesn’t require me to be in run when running the locate learned keys
I just ran this
Lawsuit11
Fort Worth, TX
Try and start your truck but use the key fob to push the push button to start. Don’t use your finger actually use your fob to push the button. Mine has asked me to do this once when I attempted to start my truck multiple times without the fob in range.
whitezracer
Ripley, Tennessee
I see it has a bcm replaced option on Alfa and it says “Use this function when the BCM has been replaced. It will create the BCM backup of the secret key value stored in the RF-hub.” The hub I bought is the correct part number for my year model truck when looking it up online but I bought a used hub from a truck in a junkyard so could it be because the PIN number in my bcm does not match the PIN number in the rfhub it won’t let it turn on? I know when I programmed the key I could not use the pin to my truck I had to use the pin to the truck that the hub came out of.
whitezracer
Ripley, Tennessee
I have tried pushing the button with the fob but it does nothing.
Lawsuit11
Fort Worth, TX
There may have been an update for alphaobd in the past 24-48 hour's. Check and see. You may need to update
2018 2500 6.4L Tradesman
Yeah we had an update today for the correction of the 7” evic. It works now
1500ram12
5.9L Cummins
Awesome. I knew I should of checked today. Now I have to wait until tomorrow
1500ram12
5.9L Cummins
If you look in Alfa I posted screen shots
Just saw them. I wish I had my truck tonight at work, I'd do it on my break. I keep my old note 5 in my truck for those random urges to change or look at something while at work.
Lawsuit11
Fort Worth, TX
Lmao I have my lg stylo in my truck at all times. For the same reason [emoji23]
whitezracer
Ripley, Tennessee
Are the Rams like the Durango because if I get in my wife’s Durango and push the button without the fob in the car it will show on the evic “key fob not detected”
I am not getting any kind of message on the evic at all besides push brake and push button to start when I first open the door. It’s like the truck does not respond at all to me pushing the start button where my wife’s Durango will atleast show key fob not detected when I push the button without the fob in the vehicle.
Lawsuit11
Fort Worth, TX
Yes it is the same. Have you tried disconnecting the battery to get the bcm to reset?
whitezracer
Ripley, Tennessee
I just went back thru and unslected all the keyless options with alfa and let the truck sit for about an hour to let that take affect. After that I went thru and activated each keyless option one at a time and let the truck sit for about 30 mins between each change and once I had all 4 activated I tried again and still the same thing. Has anyone else installed this on a 2014 Ram 1500, are there any other options that need to be activated in the bcm to make this work besides the 4 options in the beginning of this thread.
1500ram12
5.9L Cummins
Did you say you didn't have your antennas installed in hooked up?
1500ram12
5.9L Cummins
Are you using the android or windows version
Island-cowboy
