How to Add Overhead Console
Solej
Just ordered my overhead console with homelink, to replace mine that doesn't have homelink.... I'm way to excited about this... Lol
R.L.K.
Bristol , Tn.
Good luck
Solej
Good luck to you sir !
If you had the O/H CONSOLE already with compass module that worked , you will need a dealer to flash the CV2 sales code for homelink to work .
If you did not have the o/H console previously you will require the dealer flashed codes CUN & CV2
HOPE THIS HELPS !
Thank you, I did not know that. I will have to add that to my list.... Lol
Ricks Ram
If your truck has the RA2 radio with the compass and the overhead console already it's a plug and play you will not need to add any codes the CUN and CV2 codes should already be loaded in your truck. Just pull down your console remove it and plug in the new one. It's important that you make sure you install a Homelink/compass module for a 13 and up.
R.L.K.
Bristol , Tn.
My bad Solej , I thought you had an RA1
Truck , I looked back and seen you already had the O/H Console with compass , so you must've had the RA2 already.
Anyways some good info on troubleshooting and required codes for radios and cluster regarding the compass signal can be found here http://www.ramforum.com/showthread.php?t=77656
Compass not working ?
Hope this helps someone out !
Solej
No problem, yep I have the console already with the RA2 radio with compass, I will let everyone know the outcome as soon as it gets to my door step and installed!!
cptwing
The Soviet State of Connecticut
2014 3500 ST DRW REG CAB
6.4l Hemi
Mine came with the RA1 with no console and then I added the console with the home link it was plug and play, no compass on the radio after I upgraded that but the homelink works perfectly and shows up in the evic no codes required.
Wareagle32
Fairview tennessee
Console for sale
I have an overhead console for sale. Looks good. Dosnt have the home link, rear window,and sun roof blanks in it. Give me an offer for it. Pm me for further details.
Wareagle32
Fairview tennessee
Overhead console
I will take pic when I get home. I don't know how about 20$ that includes shipping.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Does it have the sunroof buttons?
Wareagle32
Fairview tennessee
Console.
No sunroof buttons. The slot for it and the sliding window and home link are missing the blanks that go in the slots.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
OK disregard...sorry.
Express Man
I have a question I just purchased an overhead console that has the rear sliding window switch in it. I don't have a rear sliding window in my truck and was wondering if I can change it out just that piece with a plain one and what the part number would be thanks. Or if someone has the plain piece and wants to trade I would be willing to. Pic is below what I'm talking about.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I have a question I just purchased an overhead console that has the sunroof switch in it. I don't have a sunroof in my truck and was wondering if I can change it out just that piece with a plain one and what the part number would be thanks. Pic is below what I'm talking about.
Interested in a possible trade? You send me the switch, I send you the filler panel?
WadXpress
HEMI
I have the plain express one with just the maplights. Could you rig those buttons on the upgraded model like above for the sunroof or rear slider to turn on leds or whatever you come up with? I know you can use the dead buttons in the dash I ordered a pushbutton switch to try to make a button work. Just curious. Thanks
I'm just getting a little confidence in doing electrical work in the truck but im a noob to it so if it would be a huge pain then I'd rather not try
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I'll send you a private message.
Sorry, please disregard. I saw your post originally without the picture. Just so you know, that switch is the rear window slider switch. The sunroof switch is a 3-button switch.
Express Man
I hear you I'm kind of scared at doing this. I might try and get someone to do it for me because I have no experience in electrical at all lol I'm sure you could use it for other stuff if you wanted to. But wouldn't know how.
Benvolio36
Connecticut
I just installed a overhead console with Homelink. I had the compass and it was an easy plug and play. Works great with my garage door!!!
