Start by removing the A-piller covers and sun visors. This will allow you to get the headliner down enough to get the retainer in. It is secured with the sun visor clips.
You will have to remove the two small black clip brackets. The retainer bracket replaces them.
Then remove the headlight switch panel and the left side panel. These just pop out. Behind these you will see a green connector. Removing the left side panel of the dash gives you all the access you will need for the next steps.
This plug is where the overhead light wires and constant power you need. The middle bottom three pins. Middle one of the three is where you need to tap.
Black/Tan is ground
Yellow/white is overhead light (allows console to work with doors)
Yellow/Lt Blue is Map constant power (this is what you need to tap.
Just pop off the inner white retainer on the green plug and use one of the connectors with the pin-out kit and push it into the green plug. Then snap the white retainer back in.
This is how you wire the pin-out for the console.
I tapped the stock overhead light wires at the base of the A-piller for ground and door/switch power. When you take it apart you see a good spot. Same Yellow/White and Black/Tan wires.
