how to fix headlight adjuster
doitmyselfer
smithers, b.c. canada
2012 ram 1500 quad cab
Anyone have any idea on what I need to fix or replace, so I can adjust my drivers side headlight on my 2012 ram 1500. Right side adjusts fine. Took it to a shop now they want me to go to dealership and pay top $. As it stands my drivers headlight is aiming directly in front of truck and it suxs. Need it fixed asap. Any ideas anyone and hopefully I can get to try my new headlights out properly. Thanks
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
does the inner bowl move? I wonder if it popped off the adjuster?
D
doitmyselfer
thank you for any advice
I'm not sure if its in the bowl or not. I plan on taking it out the headlight again this weekend to make sure I haven't put it in wrong. Now with u suggesting to check the bowl I will do. I appreciate any input or ideas. If its not the bowl its gonna cost. Is the bowl directly under the adjuster screw?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
cross post......
it sounds like it just popped off the adjuster, which is fun to fix.......hard to pull that bowl back on the ball when its popped off - but its doable. easier if you remove the adjuster, put some ky on the end and shove it in. giggity
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
the bowl is what the bulb is in, the big reflective thing there. the adjuster is at the top of the bowl.
D
doitmyselfer
Thanks again I am totally going to check that before I spend any major money. I have other plans for my money on my truck. Hope that's all it is.
Rgesse
