how to get more lift?
BAMA BOY
Gasden,Alabama
4.7 Liters of fire breathing fury!
is there anyway i can get another 2 inches out of my truck being that i have torsion bars, i know i can out a block in the rear but what would i do for the front?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Being your already cranked you could get keys and crank it more but thats alot of pressure. When I put Skyjacker keys on mine and turned them 10 turns a peice I had 4inches of total front lift so I had to back em out.
BAMA BOY
BAMA BOY
Gasden,Alabama
I cranked mine four inches already just to level it out
4X HEMI
Lancaster County, PA
Holy CRAP! The front end of the 3rd gens only sit 2½" lower then the back, if you crank the torsion bars 4 to 5 times you will get that 2½" back to level it out. Don't know what is going on if you raised it 4".
If you want to go higher, you can either put 35's on it which will give you another 2" from the factory 31's (unless your truck came with 20's, then it would be 33" tires and will only give you 1") or you can get a 2 or 3" body lift.
Other then that, the only thing you can do is a suspension lift.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Damn 4inchs off the stock bars and its level? At 2 mine was nose up...
BAMA BOY
BAMA BOY
Gasden,Alabama
id be ok with a body lift but i would need brackets for the brush guard
ramhunter9
P-Star Jeep Wrangler
yes but you can fab them up pretty easy .
4X HEMI
Some of the body lifts have brackets to bring everything back to where it was before, just allows for the difference in height.
Mine is from Performance Accessories and it pretty much had everything there. My front light bar mounted right back up to where it was before the body lift.
Bad Habit
Land O Lakes
Modded 4.7l
Whilst y'all want to get your extra inches, I'd rather go a lower for better handling and performance...Room maybe extra room in the garage...
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Hey Jay can ya pass some of the inches you're taking away and give those to Bama??? He needs a few more. lol and for those that want to shed some inches around the waist. Pass those inches to shiloh... He could use them. lol
Oefootball_70
OLATHE
My wife would be pissed if I got two more inches, on my truck.... or other places...
dakota18
