I changed the EQ Curve to just what you and Lawsuit11 suggested, Quad Cab 6 speakers.
BTW the subscriptions active on this radio are XM, Travelink and Traffic Plus. Is there something I need to set or an icon I should be seeing for the Travalink or Traffic Plus? All my top bar show is the outside temperature and the time. I just wondered because I thought I saw some screen images showing HD and station information.
See the AlfaOBD thread document for enabling TravelLink.
HD radio stations will only show up if the local station supports it.
M² Mods.
Yeah. If you're on Application Version 18.x or 19.9 I would recommend staying away from v21.9 until the next release and see what is reported by others with factory 8.4 UAx radios.Hi all - Pulling my hair out trying to find 21.9 for the UAS. Does anyone have any leads on where I might be able to find it to save myself a trip to the dealership and a major headache trying to explain to them why I need an update for a unit that didn't ship with my vehicle?
Edit: Ah, looks like there are a bunch of audio issues on 21.9.. This is the only forum reporting such.. Interesting. Maybe I'll hold off then.
Having an intermittent issue with the navigation freezing up with the UAQ. GPS coordinates read correctly, as does travel link, but the icon for my truck stays stuck in one spot on the navigation screen. Battery disconnect doesn't always fix the issue. Anyone else seeing anything like this?
Sent from my SM-G965U using Tapatalk
That's been my go-to for issues like this as well. In this case, it hasn't worked too consistently. Resetting all personal data on the radio has been the most reliable method of correcting the problem. Odd that it works when a battery pull doesn't?I'd try the reset et todd taught me. Unhook both battery terminals and hold them together for
15 seconds and then walk away for 10-15 minutes, come back and reconnect them. I've always had good luck with it and appreciated the advise from him.
UAQ part number issue, I just got a head unit from infotainment.com guys advertised as a 2018 UAQ. The sticker on the unit says Manufacture date Aug 2016 and part number 68306656AA and I cannot find anything about that part number and how could it be AA/CP ready UAQ, didn't they only come out in 2018? I am lost.
Sent from my XT1635-02 using Tapatalk
Thank you a lot! Where would I look for the factory seal? I also noticed when I try to reply to you guys it gets flagged as "spam like" and won't let me post. So is it OK to use or I should get my money back and buy the part number listed at the top of the post. They did include a new media hub and wire harness.
Oh cool, I'm post 700...
What should I look for bug wise?You can always instal it and make sure it works. If it does awesome if it doesn’t. You can return it. Won’t hurt to try
2018 Black Pearl Ram 1500
LED Tail Lights, Black Quad Halogens with LED conversion, LED Black 3rd Break Light, Blacked Out Emblems, Rims & Grill, 8.4 UAQ conversion!, MTC to ATC Mod, OEM Remote Start
