drozek
You will lose Uconnect access and you will need a new module for the heated seats and a new media hub so u can use Apple CarPlay or android auto
What is the new module for the heated seats?
How did you fix your kilometers to mph? Mine is doing the same unchecks itself instantly. UAQ radio shows the speed limit in MPH but reads your speed limit in kilometers and shows your distance for turns etc in kilometers as well. Distance is set to US but if I try to select "Custom" it unchecks itself and if I go under custom under the distance settings menu on the radio kilometers is selected but when I check miles it unchecks itself too. 2017 Ram 2500 6.7 Tradesman with a 2018 UAQ 8.4I also solved nearly all of my problems. It is all about programming. As some of you already stated, taking a unit out of another car can make some problems. While the old Harman unit was able to regenerate from a factory reset getting all the information it needs out of the BCM, the Panasonic unit is not that clever... So you have to program all your desired (and of course supported) menu setting BEFORE installing the unit to the car. At least if you own a 2013 RAM, as I do. The "Units" settings not working are not supported by the 2013 RAM. The BCM does not have the ability to store so much information, it does only accept "Metric" or "US". Not "Custom, UK, mph, bar, kpa"... etc.). There is just 1 bit reserved for the unit information...
So for an used Panasonic you might need, depending on you MY, some kind of pre-configuration process to let the radio match the configuration list of your car. Pretty annoying...
I'm not able to find the software version like I could on my RA4. But here is my part number.What is the PN of your radio ? (See sticker on side)
What is the application version of the radio?
(Go to dealer mode... Press HOT + COLD + FRONT DEFROST for 6secs)
We had some issues with the earlier My17.5 radios (6828xxxx) on v17.x software. v18.x and newer were ok if using a 6833xxxx PN. Ram PN is UAQ 68331631 & UAS 68331635).
M² Mods.
2018 Ram UAQManufacturer date is December of 2018. Gentlemen I bought it from said it was a new radio too. If it was used would it have ask me for an unlock code like the RA4 and RA3s?
Just tried resetting to defaults on the radio and it did not work either unfortunately. I did however turn on "Speed unit CSM" with Alpha OBD earlier today and it is now under the settings on the radio but has km/h checked and when I check MPH it unchecks that and "re-checks km/h. I'm lost honestly. Trying to do everything I can to fix the issue without having to remove the radio again. I also changed the language then back to English and still no fix.i had one do the same thing.i'm thinking i used the reset to factory default setting in the main menu and it corrected back to mph.it was a uaq also didn't think it would do anything but reset the radio function settings eq etc but it reset the nav to.if that didn't work unhook the battery and touch the cables together let set for 10 min.that is the latest part number for a ram uaq and they are on back order or were as of a week or so ago canceled a order from all mopar parts as they didn't have a eta and said they had several on order.
