How to INSTALL LED Bed Rail Lighting on Your Truck
gypsy400
I doubt you get salt under and through the plastic lining of your factory carpeting. Damn brother kick your boots off before you enter your truck or get some slush mats! :roflsquared:
Trust me.. You can be as clean as possible and the salt still finds a way in.. nasty, nasty stuff!!
It's a trade-off for the climate we live in.. deal with -30 winter temperatures.. or risk getting bit by a venomous creature .
Sent from my SM-G903W using Tapatalk
wolver1385
Houston
watching your install videos makes me want to do all of the things to my truck, i dont know weather to be mad or excited lol
JB1
Houston, Texas
I was trying for that too but too many hangy down thingies (lol) to accomplish my ocd straight line complex
Luckily my lights are flexible...lol
I have ones that look similar and yes they are flexible....little too much lol
Boosted Motorsports
Boosted Motorsports
I actually ended up mounting them on the side of the bed rather than the bottom of the rail. They are still tucked way up there and invisible but it seemed to throw the light better into the middle of the box instead of down at the wheel well. Also it avoids all those "hanging down thingys" :D
JB1
Houston, Texas
that's my plan as well, just like in the vid
Pistol
I used some LEDs from Oznium. I tapped into the cab light but I also installed a switch in the bed wall and isolated it with a relay. I put a diode in the cab light line to prevent power from back feeding to the cab light. This way I can power the lights from inside or out.
Boosted Motorsports
Boosted Motorsports
Nice work Pistol! I've debated doing the extra wiring for the remote switch that is included in the kit I used but haven't had the need just yet :D
Pistol
For those wondering... my bed lights work just fine using the cab light switch when the truck is running. No trouble codes.
Reactions: JB1
Boosted Motorsports
Boosted Motorsports
Nice work guys! No idea where this rumor of the lights working and not working with the truck running. Sounds like an isolated case that somehow became passed off as true.
chrisbh17
Everything runs through the bcm and the bcm is "expecting" a certain amount of draw to each output.
It's not that LEDs overdraw the output, it's just that the bcm is sensitive regarding the output being different than what it expects (high OR low)
Sent from my Nexus 6P using Tapatalk
MarshRam
2014 SLT 4x4, 2012 ST
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
That's why I always recommend using a relay. And if for some reason the signal circuit you tap in to is PWM then a small capacitor inline from the signal circuit will stop any relay chatter. Clean, fused power from the battery is always better than tapping in to / adding to existing circuits.
chrisbh17
With LEDs I wouldnt be overly concerned about overloading the circuit.
I would just worry about the BCM thinking "I was expecting 0.5A draw, now I see 0.6A draw, Im shutting that down right now"
Boosted Motorsports
Boosted Motorsports
LED 921 Cargo bulbs I showed in another vid + the LED strip lighting used in this one = :waytogo:
JB1
Houston, Texas
Damn JB1, I'm including you in my OCD club. More like OCO since I don't feel its' a "dis"Order. Looks like you've been waxing and polishing the inside of your bed. I would eat dinner off of it if the mess wouldn't drive you nutz. Lookin good!
Lol ya the white helps to make it seem very bright
I put LED tape lights under the bed lip of my buddies 2500 w/8' bed. Tapped power off the +12V from the 7 pin trailer plug. I mounted a safety switch on the left side just under the bedrail also. He said it works great for when he's hooking up his fifth wheel trailer.IMG_20161016_200314-01.jpeg
aldosterone
So I tried the same mic tuning led install today.
Tried tapping into red in trailer harness with no success. Couldn’t get power there.
Then tapped into what I originally wanted to do which is the white with tan wire in the driver side door sill. I still have original halogen bulbs in cargo light.
Leds will blink with opening car from key but won’t turn on when button by the dash is pressed. Dash light up and then makes a weird “you failed” noise. Probably the bcm you guys keep mentioning huh?
Any advise?
2017 Ram 1500 Hemi Express
