How to know if lifted
Raife
6.7 I6 Cummins HO Turbo Diesel
Good evening. I have a basic and maybe ignorant question...how do I know if my truck has been lifted. It is my first truck and I bought it used (I didn't ask the dealer when I bought it).
2020 Ram 3500 CC LB Larimie
Thank you.
Nick@GotExhaust
Supporting Vendor
SC
Have you brought it to a RAM dealership and parked it next to another 3500?
To start
Is the front level with the rear?
lets see some pics from the side
show us pics of the coil springs make sure to show bottom and top of coil where they mount
TwitchCaptain
California
2021 Classic
Does the tire size match what's in the door jam? If yes, probably not lifted. That's not guarantee, but it's a good thing to check. Best way to know if it's lifted is to compare it to one that's not.
R
Raife
Thanks. I'll get some pics tomorrow. I have not compared to one on the lot. The tires do match the door jam and the front and rear are generally level.
R
Raife
The truck does have the factory rear air suspension. Here are the pictures...
Cmz2800
NC
I have a better question: what makes you think your truck was lifted to begin with? That truck doesn’t look like it’s been molested. Looks as long as a school bus
Cmz2800
NC
That gap on the leaf springs does look a bit suspect but I have never had one to compare to therefore I have no clue
White six four
Wisconsin
Looks stock height to me. If you clean the "tag" on the front coil spring it should have an oem part number on it to double check.
R
Raife
Only that it is high, but I have never owned a truck before so wasn't sure.
R
Raife
Thank you
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
All stock at a factory ride height. The 3500 do sit up higher than the 2500’s the 1 ton trucks are no joke.
Truck is beautiful good luck with it.
Neomoritate
Chicago, IL, USA
This is a common design in HD pickups. The upper leaves are for comfortable unloaded driving, when you add a heavy load, it sits down on the additional leaves.
olyelr
Kewadin MI
Actually, i think it probably hits that pack with every day driving with his setup, even without towing. He has the factory air option, so the leaf pack is very light duty in comparison to a normal 1 ton.
olyelr
Kewadin MI
Per your question in the pm you sent me, the sway bar link is what attaches your sway bar to your axle. The joint where the arrow is looks quite blown out…
R
Raife
Thanks. I did some research after I saw your comment and believe I found the OEM replacement...did does look a bit different. I'll get under there in the next couple of days and get a better look at it. Also watched a couple videos on how to replace and seems straight forward.
Thank you.
olyelr
Kewadin MI
Welcome! Yep thats what you are after.
Straightforward easily replaceable part. But rust and corrosion might fight you a bit.
KAKA
