I heard If u hold the ESP button for 10 seconds it turns it off completely ?
Not the case.
The only way to kill it is to pull the fuse to the ABS module.
I've though about running an interrupt switch to the cab.
Just in those situations where I need to do a burnout.![]()
Buzz Kill Alert: While I can see why you'd want to lay peel at the track, other than smoking the occasional teenager at a red light, all you're really going to accomplish is early tread wear and maybe get ticketed for demonstration of speed and power (or whatever the local vehicular nuisance ordnance is).I Have A Question For You??? Latley I've Been Hearing About This Catch Can What Is It And Does It Help Any Performance Wise....
And Reason For Traction Control Is I Can't Get The Truck To Spin It Will Spin For Seconds Then I Will Lose Thorttle
Maybe I'm just getting old....![]()
