Hub assembly rear
duckman631
New Jersey
2016 Big Horn Crew Cab
Hemi 5.7 K&N Cold Air Intake.
So I want to replace the front hub assembly’s which I assume is a wheel bearing with the studs. (Correct me if I’m wrong). At the same time I want to do the rears. I don’t believe the rear is the same type of assembly. At least I can’t find. Can someone tell me what I should be looking for to replace the rear bearings? 2016 1500 5.7 110,000 mi. 4x4.
duckman631
duckman631
New Jersey
Thanks! Out of stock on rears but I will keep an eye on it.
EagleChief
Oklahoma
2014 Big Horn
Those fronts are a much better price than what I paid in an emergency. I waited until one of front hubs went out to replace it. I had a discount at a local parts store and still payed almost $200/each for the fronts. If I would've had time to wait, this would've been the way to go.
I had a friend help me change mine and it took us about 3 hours total to do both front hubs. First one took longer, of course. Second time through maybe took us 45-50 minutes.
Reticle918
