Hi Everyone,
We have had a lot of customers asking us for a plug and play solution for hyper flash. Those of you that may not know what hyper flash is, it's when you change your turn single bulb to led and your light flashes fast and your dash indicator flashes fast as well.
There was always a traditional solution for hyper flash. Which was cutting and splicing into the wiring harness with a 50W 6Ohm Resistor. Which a lot of customers didn't like the idea of cutting into the factory wiring. So we designed a wiring harness that is plug and play. It plugs inline with the oem plug and led bulb, no more cutting and splicing!
Here is the link to the 3157 Plug and play resistor harness.
https://undergroundlighting.com/products/3157-plug-and-play-resistor-stops-hyper-flashing-errors
