I found a way to receive your own PIN CODE without the dealer :)
Jimmy07
He must have gone live with it - I was able to read mine 2 days ago through AlphaODB (of course after paying for pin puller app). They matched. And mine is regular from Play Store.
Yup, same here. Mine was read correctly this weekend with the new update.
deathbyburito
Minnesota
3.0L EcoDiesel
I got the updated AlfaODB a couple of weeks ago from the developer (great responsiveness and help) and was able to pull my pin. Sounds like it is fixed in the main version now which is great.
tnctx02
2017 RAM SLT
3.6L Pentastar V6
How do you pull it with AlfaOBD?
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Select Function
Radio Frequency Hub
Select Control Unit
Radio Frequency Hub
Connect
Select the Open Hood Fiat icon
Select Procedure to Start
Scroll Down to Read PIN
Follow Directions
Thanks so much! It pulled the same number I have already! Looks to be working good!
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Thanks to the guys following up with this.
I used AlphaOBD last night to pull my code and it worked! CONFIRMED.
shopman
Minnesota
2015 Laramie Longhorn
Tried on My 2015 1500 5.7 didn't work have to read up no this???
This is what I get when I try
Running Alfa OBD Ver. 2.2.0.0
Any Help??????
67 StingrayJ
USA, New Mexico, Las cruces.
Thats crazy. What if you ever need to reset your radio? Do they make you pay for that code too?
Seriously think its a load of crap that you cant freely get the PIN for your own darn truck. Some US dealers seem to be taking advantage of the situation too, luckily mine did not. If they had, I would have paid for the PIN puller instead just out of spite for the dealer.
Totally agree with this statement. It's your own darn truck. It's just another money grab for the dang dealerships i tell ya.
Down with Dealerships!
Scott42001
Paducah, KY.
4.7l v8
Yeah alfaobd all the way. Find someone close to you that has obdlink mx+ and alfaobd, they can read your pin. Takes seconds. MY location shows on the boards. IF someone is close i dont mind doing it, cover my gas if need be.
SeppW
Northern VA
Hemi 6.4L
Worked for me on '16 2500 Tradesman Power Wagon.
Flammable_Solid
Mesa, AZ
Don't go to the service department for the PIN since they have to go to the parts department. Go straight to the parts department. Bring your registration and drivers license. Tell them you want your RF Hub PIN not the key code PIN. If they ask why you want it tell them because it is information about your truck that you are entitled to receive.
Just back from the dealer. They had no idea what the RF Hub PIN was. I have the key code now and and ignition code.
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Confirmed the AlphaOBD method worked on my 2017 Ram 1500 Sport down here in Australia. Awesome stuff
Worked on my 2017 and my 2013.
yomanne
Cedar Falls, IA
So I used the OBDLink MX OBD2 reader and downloaded an app called Pin Puller.
It says it need elm237 pr something but when you connect using Blietooth it says its using the MX like an ELM!! From this point you than click on the model vehcile you have and purchase some points. For pin code its 50 points and costs $19.99. After that cost start. It asks you to put your 4 way emergency lights on and the n click continue. Moments layer it shows VIN and your pin code!
Hope this helps others with reluctant dealers!!
You can also get the 4-digit keyfob pin using alphaobd by connecting to the "Radio Frequency Hub" and choosing "Read PIN".
DonAlex1053
USA
EcoDiesel
I have an OBDLink MX+, bypass cable and alfaobd. I've been trying to read my pin for a few days now but every time I press the start button nothing happens.
Gordo2212
Mississippi
2018 3500 Tradesman
6.4 L Hemi
I'm in the same boat. Going to be installing OEM remote start and need the code but every time I hit read pin in the RFH section it just sits and nothing happens. Is there a long wait time for it to do its thing? I don't get an error or anything maybe I just need to be more patient lol.
DonAlex1053
USA
EcoDiesel
I think my issue is that I'm using the security bypass cable from my SFT tuner. Its an AEV security bypass cable. I'm pretty sure it doesn't bypass the SGW in the hub. Later today I will trying again with a new cable.
Gordo2212
Mississippi
2018 3500 Tradesman
6.4 L Hemi
I went to the dealer today and they gave me the pin no questions asked. Took about 10 minutes.
Sking80
Atlanta Ga
Any luck on getting it to work. Mines does nothing. I’m just waiting and waiting ver 2.2.5.0
