I need My gig info!
Ram1019
I can get a great price on a what is said to be a 2010 my gig serial number P 05064818AB and wanted to know if it will work in my 2011 i have serius satilite radio.
LB3711
Trumbull, CT
3.6L V6
It should but sirus is in the radio so you'd have to add the new radio on your account. If the radio your getting has sirus in it.
Sent from my tapatalk equipped AT&T iPhone 4.
R
Ram1019
Thanks for the help my seriusis expired and probably not going to subscribe.I just want to make sure it fits and also wont need a dealer to program it.
LB3711
Trumbull, CT
3.6L V6
Then you shouldn't have any problems
Sent from my Transformer TF101 using Tapatalk
LB3711
Trumbull, CT
3.6L V6
no. The sat attenna plugs directly into the back of the radio. Ucconnect is the seperate module
mikeb33
2012 1500 2WD express
My mistake. I had a 07 Charger and took the CD changer out and put in a REC NAV radio and my EISN stayed the same. I assumed the Sirius model was elsewhere and just plugged into the radio.
LB3711
Trumbull, CT
3.6L V6
It might be different for the radios before the my gigs. My mothers vue has the factory xm separate from the radio.
R
Ram1019
I am pretty sure the Sirius is a separate module. You put in a new radio, but you still have the same EISN.
More important is whether it is a REC, REN, RBZ, etc?
This chart will help with what works for you: Jeep Grand Cherokee WK - MyGIG Multimedia Infotainment System radios
The radio is a rer model the chart says yes on a 2011 as long as its high speed bus and also at the end in comments it says will not work with prior year models....? Thanks for the link I think im going to give it a try and see if it works.
quietpeen
2021 TRX
Hellcat
nice, how do you like the new radio
