ID / OD question
ramhunter9
P-Star Jeep Wrangler
Getting ready to order some new stacks ... Aussie 6" but having trouble with one thing ?
The stack is 6" my exhaust is 5"
I need to get a adapter but dont know or understand the ID and OD thing ?
Do I need
Exhaust Adapter 5" OD to 6" ID Aluminized
The little part goes in the 5" exhaust and the bigger end accepts a 6" pipe ?
HKkid
Missouri
Yes, a 5" OD pipe will slide into a 5"ID pipe, and your new stack will slide into the other side.
HKkid
Missouri
You may want to measure your current setup so you know if the pipe is 5" ID or OD. If its 5"OD it won't work, but if its slightly smaller you should be fine.
ramhunter9
ramhunter9
Here is a pic
I know the stacks are 5" and slide into the exhaust that is 5" , The exhaust is slightly bigger than the stack
HKkid
Missouri
Uhh...stick a tape to the top of the stack and see if they are 5" OD or ID. They should be ID, meaning the OD diameter should be just a tad bit larger.
ramhunter9
ramhunter9
It looks to me a hair under 5"
HKkid
Missouri
They're 5"OD...so that adapter should be fine.
ramhunter9
ramhunter9
Ya , so explain this all for me 1 more time ..lol
HKkid
Missouri
So the adapter you are buying is 5" OD, just like what you have there, as in it will slide down over like the stack does there. Then the new stack will be 6" OD and slide down over the adapter which is 6" ID.
ramhunter9
ramhunter9
Wont the 6" stack slide in ? Like the 5" does now in the exhaust ?
HKkid
Missouri
Had to look really close at that pic to see that. Ok if that slides in, then yeah the 5" will slide in, the 6" will slide into that.
Wow this got confusing quick.
ramhunter9
ramhunter9
So the smaller end will slide IN the exhaust (like the stacks do now) and the new 6" stacks will slide into the adapter ?
ramhunter9
ramhunter9
Dam , why didnt ya say so .. LOL
HKkid
Missouri
Dear Dave,
The adapter you have chosen will work.
Thanks,
Cody
ramhunter9
ramhunter9
LMAO
Thanks
Stangshcky12
Oshkosh, WI
5.9 Cummins
lol
go with 8" ausies.
Kidding. I used to really like aussies but I think I'm a bigger fan of slash cut anymore
Rgesse
