ID Part
Etchasaw09
4.7 V8
I have 2009 4.7 V8 SLT. When we were taking apart the hose and wiring my brother in-law friend broke this piece. I have searched online and cannot find what the name is. It’s located on top the engine by the spark plugs.
Find some rubber fuel line hose that fits over it fairly tight and patch it back together.There's enough left on each end to piece it back together cheaply with rubber hose
Tach_tech
5.7L HEMI
Either for the purge valve, or the PCV valve on the driver side valve cover. Looks more like the PCV hose to me.
Etchasaw09
Etchasaw09
4.7 V8
Thanks Guys for the response I got the part for it and will be picking it up tomorrow.
this is the final piece I have left before I close up everything else. As you can see it has a bracket with two bolts. I have tried and tried to find where this mounts too but I have had zero luck.
if you have any information on where this things mounts too it would be a world of thanks. It is located under the driver side just below the purge valve or PCV Valve. I got it stuck twice trying to figure out where it mounts too.
thanks again for your help. Didnt think anyone would read my post lol thanks guys
