idle problem
operator15
2004 hemi 5.7 with idle problem I change coil, spark plug, clean injectors, cables .
and still idle ruff .rpm don't past 4000 any help
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
If you have done a trans service recently it is possible the filter is not seated properly, otherwise just check you fluid level to make sure it is spot on. Any codes?
