I'm curious
Dark Knight 500
Alberta
What is everyone's take on driving without front fender liners? Mine are destroyed from constantly being kicked back into the tire.
I know their primary purpose is to protect the engine bay from crap being kicked up from the road, but I wanna know, would you or wouldn't you drive without them.
huntergreen
Marine Corps Navy Badge
With all the electronics and all the plugs, I would not drive without fender liners.
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
Besides protecting from road debris they also help keep a lot of water from spraying into the engine bay when driving on wet roads. I would recommend not running without them on modern trucks.
Dark Knight 500
Dark Knight 500
Alberta
Had anyone seen liners that are more rigid than the flimsy oem ones?
Magfan2
Montana
Had the front ones replaced on my truck as they were damaged badly when I bought. ****** expensive for plastic crap, but I am told necessary if the truck is to outlast me!
Bigskyroadglide
Moderator
Member Relations Specialist
Montana, officially RETIRED
Hemi 5.7, supercharged
I purchased some fiber ones off ebay to replace the plastic ones that I rubbed through with tires hitting on bumps after lowering my truck 4 inches in the front.
They are holding up well, but plastic was easier to install
olyelr
Kewadin MI
Ive never had an issue with the fender liners on either of my 4th gen’s (roughly 300k combined miles on them). I will say, though, the ones on the half ton are definitely more flimsy than on the hd’s. Completely different design.
I would definitely put a set back on, even if they were oem ones.
My ‘26 half ton came with only a potion of the rear wheel wells covered (only the front and back…the top side is wide open). This makes absolutely no sense…almost p!s$es me off. Im gonna try to find a full plastic liner for it. DUMB!
5150Eddie
SE Ohio
Diesel 5.9
I would definitely replace them. If you are in the North you don't want wet road grime, mud, and wintery salty slush up in your fenders & engine compartment, let alone your electronic components.
Hardracer
Swfl
2010 1500 laramie 4x4 crew cab
Why are they being kicked back into the tires?
Sounds like another issue that should be remedied....no?
Tell us what's goin to cause your problem.
Daw14
South Florida
Replace them , a heat gun can work to help permanently change the shape of the plastic liner.
A few Christmas tree fasteners and or zip ties can help to keep things in their proper position.
