Inez Hotrods 4/6 Drop
modifiedloser
Me and a good friend spent the last two days installing the 4/6 drop from Inez Hotrods and some hellwig swaybars front and rear and an Air Lift 1000 kit from Moes Performance.
It gets aligned tomorrow and then I'll relaly be able to go out and test it, but so far we never hit bumo stops and the front feels just like normal while the rear is only slightly rougher. I also haven't aired up the Air Lift 1000 bags yet.
Sent from my SM-G935V using Tapatalk
Quicksilver337
South FL
2016 Ram R/T
Your truck looks awesome!! I was wondering when someone would install the Inez Hotrod setup... So did you get the front lowering arms ? and how was the instal?
charonblk07
Calgary, Ab
F1-A forged 349ci
How far out did the front wheels get pushed, they look like they're sticking out a bit
M
modifiedloser
It hasn't been aligned yet so what you're seeing is positive camber at the moment. I'm actually replying from the alignment shop right now. As far as I can tell they won't stick out at all.
The install was pretty straight forward. I don't own a car lift or a plasma cutter, but if I did we could have shaved several hours off the install.
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
what size tire are you running?
M
modifiedloser
The alignment went perfect and the dealership service department was pretty impressed with the setup.
Here are pics post alignment to show that the tires don't stick out with this kit.
285/50/20 Nittos
Demon-HeMi
Houston
now some full sun shots brother!!!!
M
modifiedloser
Here ya go.
Also I feel like mentioning that I kept the bump stop cups and just cut down the belltech bumo stops about an inch. So far I haven't hit them.
Demon-HeMi
Houston
love it, looks great, you need to get some headlights on that thing and dump the duals!
these would be clean on your truck with the black wheels
Demon-HeMi
Houston
ha you replied before i could finish my edit about the headlights! lol
285/50/20 Nittos
When you say the alignment went perfect does that mean it aligned right to the factory specs?
Quicksilver337
South FL
2016 Ram R/T
so what did you use to cut the rear top control arm support bracket?
noraa73
