Inez Hotrods 4/6 Drop
M
modifiedloser
so what did you use to cut the rear top control arm support bracket?
A cutoff wheel and we just cut it up into sections until it was all off. Plasma cutter would be way better but wasn't an option.
Sent from my SM-G935V using Tapatalk
Quicksilver337
South FL
2016 Ram R/T
yup I agree plasma cutter would be easier... I was thinking of buying a cheap one for $300 but don't know if I would ever use it again :shrug:
R/T_Fire
Pleasant Grove
That's what craigslist is for...
But I hear the one harbor freight has actually isn't bad.. just not sure how long it lasts. I'm thinking of buying one also, but I will use the crap out of it... I have a tone of fab on may projects that I need to do and is hard to take to the farm shop all the time to do it.
sriley531
Ohio
I bought a plasma cutter when I was restoring a car and had a ton of sheet metal work to do. Got mine from Eastwood. It is flat out AWESOME and worth every penny! I highly recommend to anyone doing much metal cutting to add one to their arsenal. The time and effort it saves over a cut off wheel is insane.
THETANK
up jor *** mang
2015 R/T
loving the stance, strangely the first pics in the darker setting showed the stance to be higher than the outdoor shots. Hey my eyes are not 18 anymore lol. Congrats on a great job and an even greater stance. I will stay with my paltry 2/4 Belltech for the foreseeable future.
rtorres51
Lubbock, Texas
Looks very cool, thank you for the pictures. Was the front control arms straight installation, did you have the modify the tie rod ends? Just wondering before I purchase kit.
M
modifiedloser
Nothing has to be modified. They designed them to work with the stock setup.
Fernydawg13
Hey man I'm in the process of doing it and I noticed that my front endlinks are to long, did your kit come with endlinks?
M
modifiedloser
No, everything was fine with mine.
M
modifiedloser
Also, I've done about 1000 miles on this kit now and it's pretty awesome. The rear shocks suck, but I'm going to order a custom set from Ride tech.
Other than that I have nothing negative to say about it.
predat-r
4.7 v8
Damn thas an aggressive drop......looks good.
Sent from my SM-N920P using Tapatalk
ramittome
Gonzales, LA
Does the rear shock mount location change? I ask because I know the back shocks suck with this kit and I'm still uncertain if I want to go with this kit or the McGaughy kit, but either way I'm going to upgrade to UA1 shocks, so was wondering if the rear changed location, or it the shorted UA1 shock would work. Thanks!
Quicksilver337
South FL
2016 Ram R/T
shock location stays the same, the Inez drop kit is more of an aggressive drop than the Mc G. What is used with this drop is the Belltech springs and recommended QA1 shocks. Stock shocks are out of the question
ramittome
Gonzales, LA
Isn't the belltechs only a 4" drop? How they get the other 2"? And I know the front uses all the stock stuff, just different control arms, correct?
noraa73
