Inez Hotrods 4/6 Drop
ramittome
Gonzales, LA
I spray painted mine.... done. IMO powder coating the arms is a waste of money unless it's a show car. I agree they should of packaged their products better, you would think they knew how to properly package by now :emotions122:
Not really a show car, persay, but I do like my stuff to look good when installed so I don't have to redo anything. And occasionally I do go to shows although it has been quite a while and only one in this truck. My old car I had hit up about a hundred shows in the four years of owning it.
rtorres51
Lubbock, Texas
Just installed the Inez drop kit. I just installed the rear brackets for now. Will install the front control arms at a latter day. The rear end is centered now. Don't even think of installing this drop kit without a plasma or torch cutter, I had a hard time with cut off disc. It was a very long day. I didn't have much motivation to proceed to the front to install the front control arms. I strongly suggest a plasma cutter or torch cutter.
I will have to fabricate a bracket for emergency brake cable. The cable rubbing against the exhaust. Need to purchase Air Lift bags for the rear. I will need to cut the rear bump stops off when I'm finally done installing this kit.
GOOD LUCK LUCK IF YOU PROCEED WITHOUT A PLASMA OR TORCH CUTTER.
ramittome
Gonzales, LA
Between last night and this morning I installed mine. Took roughly 9 hours by myself. Cut off all the bump stops, because, well, who needs those anyway. Also cut off everything with a combination of a cut off wheel and a sawzall. Took a few minutes to do it that way, but I don't have a plasma, and the guys I know down the street that own fab shops didn't bring their work trucks home this weekend, so I was out of luck. I just cut 1 ring off the backs for the time being. Gonna let them settle some before I cut anymore. Also got some airlift bags in the rears pressured up to 5lbs.
Quicksilver337
South FL
2016 Ram R/T
Congrats!! looks awesome! Inspiration to do mine:favorites13:
predat-r
4.7 v8
yup it's a crossmember bracket
since I have a RCSB I don't need it :signs8:
here the install instructions...
Front
Rear
I know people said that I could still install the belltech rear kit but seeing that the rear cross member is diff what is my options?
Sent from my SM-N920P using Tapatalk
Quicksilver337
South FL
2016 Ram R/T
The reason the cross brace is used is due to the drive shaft possibly touching the underside of the bed. It states that it's used on certain trucks, not all
predat-r
4.7 v8
Copy that.
predat-r
4.7 v8
Hey guys anyone not using there 2wd oem from spindles let me know needed to complete drop!!!!!!!!55648a48c6bb747c552f11b9e50d9a62.jpg
Slammin Samson
AZ
Looks sick! I been searching for awhile on google for something lower than my belltech drop kit and couldnt find anything. Till now!
Thanks lol
salazarn54
Well I just pulled the trigger on the Inez drop kit. Going with a 4/6. I live in Houston so I'm taking the drive and having the man himself install the kit. Ill keep you guys updated
Quicksilver337
South FL
2016 Ram R/T
I wish I lived closer to Texas... so I could of had Inez install the kit for me.... let me tell you it's a lot of work doing it by yourself.
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
when you get back to houston let me know, we can meet up, i wana check it out
rtorres51
Lubbock, Texas
Not sure. i half of an inch distance from the inside of tire to outer upper control arm. Not much room.
jedeisurf
Glendale AZ
Ok cool are you happy with your inez kit ,I have been waiting to here some reviews before I buy.
Thanks
