Injectors??
JP03
New Jersey
Cummins 5.9
So, iam aroud the time when i heard they are going to need to be replaced (150,000) miles so is it safe to go with 50hp injectors or stay with stock injectors only mods i have done are edge juice with attitude, 4in mbrb turbo back exhaust,k&n cold air intake
ramhunter9
P-Star Jeep Wrangler
A set of 50's will do you good bud . If not at least a set of RV injectors .
Hit me up when your ready I will give ya a hell of a deal on a set .
JP03
JP03
New Jersey
Cummins 5.9
Even with the stock turbo? i do tow alot if that makes a difference and Rv injectors?? never heard of them
ramhunter9
I used 50's on my stock setup with a tuner .. never a issue .
And RV275's are basically a beefed up stock injector .. You will have no problems running a 50 hp stick .
JP03
JP03
New Jersey
Cummins 5.9
Oh ok and thanks for the info definantly will be going through you when the time comes
ramhunter9
10-4 bud
JP03
JP03
New Jersey
Cummins 5.9
sorry last question signs are basically hard starting right? or has it already gone too far when you get hard starts?
ramhunter9
Hard starts is a cause , also I have seen bad fuel pumps to .
If you are at 150k on the stock fuel pump my hats off to you .
JP03
JP03
New Jersey
Cummins 5.9
well 130k but almost lol so that will need to get replaced as well might as well do them all at the same time what do you recommend air dog,fass?
ramhunter9
I am not saying the pump is bad .... but thats usually cummins week link .
I sell allot of air dog , have seen some weird things happen with Fass .
I ran the raptor 150 and LOVED it ... it is also made by airdog .
I am going to say its a injector issue or a fuel issue . Both are must have upgrades with a hot tuner IMO
JP03
JP03
New Jersey
Cummins 5.9
alright thanks for the info and when i have a problem i will just do both and they will be from you thanks again
Stangshcky12
Oshkosh, WI
5.9 Cummins
Should you upgrade to an airdog with a better filtration system your injectors may see a longer life
schroederMP
Indiana
Cummins
Also check your oil? Is your oil level rising? Smell like fuel? If so that a sign of bad injectors?
Hard Start
White Smoke
Rough Idle
^^^ Those are others signs of injectors going bad?
Got access to a fuel pressure gauge? That will help you determin if your lift pump is going bad
JP03
JP03
New Jersey
Cummins 5.9
i dont have any signs of it yet however i know its right around the corner:signs16: so iam just preparing once i get the sgns is it too late like rings shot major job too late or just change them
Jus10case
