Installed 180 T-Stat, Have Questions
Hylander
Commiefornia
Finished installing my 180 T-Stat, This is as high as it gets now.
Notice the arrow, that is where it ran before and a little higher.
Seems the 180 dropped it to about 180, where as the 195 was letting it run more like 210 and sometimes a tad higher.
I'm wondering if my 195 was going bad, it looked like the original T-Stat
Is there a way to test what Temp the truck is actually running ?
quietpeen
2021 TRX
Hellcat
welcome to Ram Forum. Somebody that know will chime in
Mopar1973Man
New Meadows, Idaho
1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Normal... Mine is the same position now with a 180*F...
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
agreed. mine might even bit a tick lower with my efan setting. kicks on a little early. nothing for you to worry about.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
That's the spot it will be in. If your still running the mechanical fan it might go to 200 then drop right back down
Mopar1973Man
New Meadows, Idaho
Use a ScanGauge II and you see it barely hits 180-182*F and then falls to 178-179*F...
Stock gauge is mis-labeled... The 200 mark is actually 190*F...
Agcat
