Darkflow
Well 1st left turn signal on the way to work this morning. The error code goes off for it. So i guess i can rule out the bulbs being the issue....
If i was using the wrong wire with the resistor, would it even work? Or throw the error right from the start? I found the info on what wires to use over on RamForumZ. So i dont think i would be using the wrong wire but just a thought
