- Mar 30, 2014
- 6,572
- 5,168
- Location
- SC
- 2022 Ram 1500 (5th Gen)
- 5.7L
Going to repost this as a start to helping Loveracing1988's camera install...
Sent from my LG G4 on Tapatalk.
Well, I decided to tell my wife what to get me for christmas, so I told her a couple different things. One of them was the setup to get the rear backup camera installed. Per this post I had her order 68197873AA thinking that it is all I needed, low and behold I have to camera, that is an extra $110. So the kit is $250 for all of the wiring front to back and all of the parts needed, or the Handle and camera separate are $185? At this point I think I am going to have her return the handle because I'm still missing a $110 camera and $90 to have the stupid sales code added. So much for thinking I was all set with a handle...
Yeh , just get the whole kit and install it yourself, pretty easy install a 4 out of 10 imo , two soldered wires and the rest is plug n play . As for the XAC sales code it took the tech @ my dealer 7 minutes, so I convinced the Service Mgr. To not charge me because I purchased the kit from them instead of less money from eBay .
Hope this helps ! MERRY CHRISTMAS!
Check this out if you haven't already , it's cptwings thread on installing the OEM back up cam . IMPORTANT INFO check out Mpgrimm2 's POST # 10 , It's loaded with good info .
Hope this helps !
Installing OEM backup cam
http://www.ramforum.com/showthread.php?p=974372
Pm me your VIN. I will check your wiring schematic and verify you have the wiring... More often than not, you will not have the full wiring installed that you think you do and end up needing parts that you can only get with the kit.
We can continue in Cptwing's Camera thread.
