Are you 100% positive about the purple wire being in pin 28?
If so, hmm...
- If you have good enough access and some patience, you can take the connector apart to depopulate pin 28.
Generally, there will be some sort of TPA lock (terminal pin assurance) on the front that will need release or removed, then a small screw driver inserted to release the pin's lock to pull the pin out the back (I haven't messed with this connector before but other have).
- 109% sure? Really sure? Cut the the wire off and use a scotch lock to splice it over to org/db wire at pin 45.
(Leave a 2" lead off the cut pin just in case and heat shrink or take it up)
Soldering is the preferred method as mentioned.
Edit: post 10 may have a link to some pictures of people doing the depopulating.
Edit 2: Nickster did it. Start at this post for pictures and possibly pm him (but he hasn't posted in a year) ...
http://www.ramforum.com/showthread.php?p=979047
@ Ktstull , if your gonna repair this yourself , disconnect the BCM C-5 remove the tape / wrap around the wire bundle to help flex it down for better access then as mpg suggested either depopulate the purple wire from the improper socket #28 or cut off a few inches so it can be attached to the OR/DB Wire in the proper socket #45 ( preferably via a good solder splice covered by quality heatshrink originally supplied in the kit )
I just can't imagine why a dealership tech would just BLINDLY STAB the purple wire in some anonymous empty #28 location when the instructions clearly state what to do with the purple wire ?
The techs obviously read the instructions ( for the most part) because everything else worked .
I depopulated both and then spliced the orange to the purple because I had a lot of extra purple wire. Taped it all and put it all back!
@wjrob
Are you just trying to get the connector disconnected from the BCM or are you trying to depopulate the pin 45 wire from the connector??
I haven't done this actual version of the camera kit so I can't really explain how to depopulate the pin totally.
Pm ktstull and see if he has some suggestions or can give you a phone call.
If you are awake between 9-11am EST, pm me your phone number and I will give you a call to explain what i can.
PS:
We could really use someone to take pictures of how to depopulate the BCM C5/E connector to get pin 45 org/db wire out.
Up All Night Sleep All Day via my LG G4 on Tapatalk
Already have the C5 off of bcm now according to instructions the "snap" cover of C5 slides off somehow to provide access to to wires for depopulation.
Oh man I just did this two days ago I wish I took pics...
There's two little release tabs on one side of the connector that you need a small flat screwdriver to release. Once released, the part of the connector that houses the pins (there's two pieces to this, one black one grey) in it will slide out the side. Really wish I had taken pics....
You can't slide each part of the connector completely out individually because of the wires (at least I couldn't) but you can get one out enough to clear the release tab so you can get the other side released. So yes you do need to get both sides out in order to splice into the wire on pin 45. Hope this makes sense....Okay this bhelps I think. I saw the tabs and was trying to figure out how in the world to release both of them at the same time to slide everything out. So it sounds like I can slide them out one at a time? Do I need to slide both out for the install? For clarification I only see one tab on each side....?
I did one at a time. I also had to take both of mine out because the dealer messed up the install. @RLK and @MPGrimm funny right? Lol
Pictures!Thank you. I will go try that very shortly!!!!!!
