Goose55
- Aug 29, 2020
- 1,003
- 583
- Location
- Ajo, AZ
- 2019
- Cummins High Output 6.7L
Wow. This is another very helpful comment, Crash. Thank you.Given that it sounds like the "DPF Full" message popped up sorta suddenly and out of the blue, I would suspect that the DPF pressure sensor may have glitched or might be flaky.
As for the life of the DPF, if you were closer to 300K miles it could be coming to end of life. Not to say that a DPF can go bad before then but there's more likely something else causing an early DPF failure.
A ******'s DPF filter can last 300,000 miles? And I experienced the "DPF FULL" message at just 30,000? Something is amiss. I'm going to message the service writer to see if I can get the rig in on one of my upcoming trips and have them look into that DPF pressure sensor. Thanks, again!
