Is bigger better??
bronx79
Montana
So Im wanting to get a after market throttle body and I'm pretty much set on a ported style of the 85mm size but my oldest bro asked me "what about the BBK 90mm?" So my question is, are the larger ones better and does the porting make the 85mm better than the larger ones? Im looking to gain throttle response most of all.
Your thoughts?
quietpeen
2021 TRX
Hellcat
not sure, but hit up hemi450hp of moes, he sells ported tb's for the hemi
bronx79
bronx79
Montana
Yeah he's chatted with me some about his and I'm certain ill buy from him. I like his website and willingness to offer up education.
Thank you.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
When it comes to throttle bodies, bigger isnt always better. I wouldnt recommend a 90mm TB unless you are running boost or a heavy shot of nitrous. That extra throttle response you gain from a properly ported TB is from the increased airflow and more importantly, increased airspeed. If you go from a 3.5" intake tube, to a TB that has a larger diameter, then the airspeed going into your motor is actually slower than it was stock. So unless you have major supporting mods to work with that extra airflow, you will actually lose a little throttle response with that big of a TB.
bronx79
bronx79
Montana
And that's the main reason I joined this forum!! Thanks again Hemi450hp
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Yep Matt has ya pointed in the right direction. For that size your gonna wanna be boosted and even then the truck maifold wouldnt show the best gains. To give you an idea this is a built Indy intake with built fuel rails injector setup with an Arrington 90 mm tb that is on out 426 stroker 88mm turbo SRT Jeep and it flows correct for all that extra displacement and boost.
Sagebrush2500
2013 2500 Big Horn
I sere you go t a good answer... a good ROT for "regular guys" like me (as opposed to the guys who were born brilliant about these sort of things) is that you always want to make sure the engine's moving air evenly through the engine and consider that sometimes one mod just isn't enough!
Good luck and enjoy!
bronx79
bronx79
Montana
Sorry for the ignorance but what does ROT mean?
