Not sure I agree with the above post taking about CAD and LSD issues. All the CAD does is disconnect the right side front wheel from the diff and don't see how it would cause any issues??? The left front wheel will spin when going down the road which spins the axle shaft, which spins the diff. With the LSD it will just spin the driver's side inner stub shaft the same speed. Maybe I'm missing something but don't see how this is an issue???
I will also say there is definitely an advantage to a LSD or locked front axle in sand or snow. Personally think it's crazy to say there is not. Sure, you don't ALWAYS need it but in seriously deep sand and snow it will help keep the truck moving forward and keep from getting stuck. It's not nearly as obvious as when rock crawling and lifting a tire off the ground, but you are not getting equal power to the front axle with an open diff as soon as they start spinning. Granted, if talking about an LSD versus locker often the LSD can transfer enough power to keep both tires spinning. My comments come from running trucks off-road and trailriding since the 1990's. I've personally owned multiple vehicles with LSD and lockers in the front axle for 20+ years.
I do think a selectable locker is a good choice for the front regardless of any of the above questions. An LSD front can cause some slightly funky handling in some situations, such as when running 4wd at higher speeds on snowy roads.
