ismy truck flood damaged?
dearidiot
I just bought a 06 ram 1500, and when i look at it with a fine tooth comb, i think its been in water... its kinda hard to see, which is why i didnt notice at the dealership, but i've replaced a few things (taken out dash, door panels, peeled up carpet to run wires) and i've noticed alot of suspicious activity....
first, in one of the heater vents, there appears to be ALOT of dust.. like its been dunked in a big mud puddle, the water dried, and left dust behind, buit its only in 1 heater vent which is weird..
2nd, that plug input under the dash (where they take emissions) has corrosion on it and looks like it got a little wet...
3rd, when i lifted the floor panels (the ones that run along the edge of the carpet) the little gaps where the clips go looks to have a bunch of gooey stuff in it.. like someone spilled a pop or something..
I've looked under the hood very closely and it looks brand new, i checked the fuse box and there is no corrosion.. underneath the truck, the exhaust pipes are pretty red and rusty looking, but i see that all the time... carfax has no report on it being in an accident.. but in the right light, you can see the passenger side door is a different color and NOT stock, also the passenger fender has signs of re-painting on it (overspray).
I was wondering why i got it for such a killer deal (bluebook $18k and i got it out the door for $11.8k). Everything works perfectly, all electronics are fantastic, the only issue is the brakes are wobbly when i come to a stop, like it has a bent rotor (?).
I dont know much about how to check for signs, I normally just tinker with interior, and from what i see, there are no stains or rust inside..
can anyone help me determine if its been flooded or not?
where are common places i should look for more definitive answers to it?
thank you very much
ramhunter9
P-Star Jeep Wrangler
wow sounds like something is wrong here . i dunno if its flood damaged or not but all sign point to something weird going on . specially with the price you paid ..
asasial
POS 4.7
i bought a stratus once that had been flooded. it was under to where only half the roof pillars and roof could be seen. i knew it was when i purchased it.
i took the interior completely out and the raw metal under dash was all rusted and you could see a line behind the panels where the water line was half way up the support pillars. look for moisture where it shouldn't be. in lights and such, pull carpet and check padding. mine was still wet and it had been almost a year. but more than likely the dealer already had it removed and dried.
Hemiguy0302
Edmonton Alberta Canada
6.2 Boss
I think this truck may have been out in the bush and hit a mud/water hole that was a bit too big. The goop in the doors and the red exhaust (result of burned on mud) indicate this truck had been used.
cheapbeater
Wisconsin
i dont think it was flooded. just rode hard and put away wet...
