- Joined
- Aug 29, 2022
- Posts
- 3,240
- Reaction score
- 7,972
- Location
- Ontario Canada
- Ram Year
- 2023 Warlock
- Engine
- 5.7
Odyssey!!!Ohhh we definitly will, and we're gonna find some agm's also.
Is there a particular brand you'd recommend?
Tyvm CanuckRamOdyssey!!!
what brand from auto zone?I had to replace my batteries last year in my 2021 2500 Cummins. It did start after 20 minutes on a charger but I was trying to go pick up our TT to run from Milton.
I bought Autozone batteries since I had to have them now.
When I tested the old batteries, one was good and one was bad.
Living in Florida I was told I got good life out of them.
I have got ten and 12 years out of batteries up here, but I take very good care of them and they are in a temp controlled garage. Despite us as outliers, the common experience matches the map. Most Costco U.S. batteries, and everyone else pretty much, have a max 2 or 3 year warranty becuase of the high heat states and not being able to have warranties that are different by region, whereas here in Canada Costco still covers the batteries for full replacemnt to 60 months and prorated out to 96 months, which is 9 years, because their Kirkland batteries last so well in our climate.I don’t know about the heat thing .
I’m in south Florida, my 04 made nine years.
While my 14 only made it to eight years.
Both factory mopar batteries.
My 14 got a Napa AGM, as they were the closest,and on sale.
My truck is a 14 , I have been using an AGM for the past three years , with no issues whatsoever.Before we pull the trigger on a pair of agm batteries, I found some stories last night talking about too make sure your vehicles charging system is compatable for both flooded lead and agm because the charging is slightly different. They said it's not too big of deal because you can always just go to a stealership and they can program your trucks computer to charge an agm properly, but I'd rather not do that. So what have y'all heard about this charging deal, is our 2020 ram 3500 6.7 hohd alternator compatable to charge an agm battery without needing to reprogram anything?
Note: We opted for the single alternator and not the duel alternator during our original build.
I went from the standard OEM factory H7 730CCA lead-acid battery to an Odyssey H8 950CCA AGM battery with zero issues whatsoever.Before we pull the trigger on a pair of agm batteries, I found some stories last night talking about too make sure your vehicles charging system is compatable for both flooded lead and agm because the charging is slightly different. They said it's not too big of deal because you can always just go to a stealership and they can program your trucks computer to charge an agm properly, but I'd rather not do that. So what have y'all heard about this charging deal, is our 2020 ram 3500 6.7 hohd alternator compatable to charge an agm battery without needing to reprogram anything?
Tyvm for researching that for us DawMy truck is a 14 , I have been using an AGM for the past three years , with no issues whatsoever.
I did nothing special, just removed and replaced.
I saw that there were questions, but I could t find anyone on this forum who claimed they had issues .
However maybe others have dead different experiences.
Cool beans, tyvm for the feedback CanuckI went from the standard OEM factory H7 730CCA lead-acid battery to an Odyssey H8 950CCA AGM battery with zero issues whatsoever.
A simple re&re was all I did with no resetting of the system, etc.
Zero issues!
I did notice my truck immediately started up much cleaner/crisper/quicker with this larger AGM vs the old stocker lead-acid.
Tyvm ram driver for that link you posted, man that describes everything you'd about ever need to know about a battery.There are many threads debating the charging requirements for lead Acid versus AGM.
AFAIC, if you're using your truck regularly, not too many short trips, the charging system in our trucks is adequate for AGM batteries.
No starting battery will survive too long with numerous short trips, especially with extreme temperatures.
I do occasionally use a trickle charger to top off the state of charge on the lead-acid battery, and understand the importance of using an AGM-compatible charger to do the same, if you choose to upgrade to AGM.
AlfaOBD has a battery type setting option, but I have yet to learn anything more than mine and others, with an OE lead acid battery is set to Battery ID4.
I've written to Alexey, and he has no information on this topic.
The 1500s come with an H7, lead acid or AGM, but the battery tray has a removable plastic block. After removal, the OE battery tray will accommodate an H8 sized battery. You would have to verify if the H8 sized battery is sufficient for your needs.
I plan to replace the OE battery with an H8 AGM battery immediately after it starts showing any subpar performance.
Battery Group Sizes and Cross Reference Chart with pictures | BCI, EN, DIN Codes
BCI Battery Groups description, sizes, charts, cross-references with EN and DIN battery codes. All you need to know about your battery replacementbatterygroupexpert.com
It's the batteries like everyone thought it was. We had pretty much given up hope for the rest of the day but still had left our little 6a charger on it. That evening decided to give it a crank and see what she'd do since it had been on the little charger for about 8 hours straight and she fired right up like it always had in the past, then wife took it for about a 30 minute spin to let the alternator finish charging it. When she got back we decided to not leave the charger hooked up all night ( because it's an ancient craftsman and I don't trust it) but decided to plug in the block heater and see if that helped it to start for this morning since the temperature was gonna be down around freezing, which we don't normally do until it's below 20*. Went out there this morning and it fired right up with no problem at all, so let it run for about 10 minutes. Then we decided that tomorrow we'd get some batteries if it started back up from only leaving the block heater on again, we're cautiously optimistic since it worked this morning.Did you get your truck started? Like everyone else has said already I’m guessing your batteries are on the way out. These diesels take a bunch of juice to get started especially if the grid heater kicks on.
Your wife is smarter than you, just like mine is smarter than me. Buy the cheap batteries, you can pay for two sets for the cost of the next ones up, warranty be damned, and 4 sets for the price of the Optimas. There isn't even a debate as to
No offense taken brotha because I agree she's definitely the smarter one of this bunch. Warranties are important to me but she can't stand spending money on a warranty that you'll probably never use. It's a gamble either way and she's the gambler, not me I'd rather throw in a few hundred extra bucks too have peace of mind. she's like you and would say for the higher price your gonna pay for the battery that has a good warranty, if you just buy the good cheaper battery and it fails after 2-3 years then you could just buy a new one for less then you woulda spent on the great batteries with the good warranty. I'll argue my view for so long but I ain't no dummy, I know how easy or hard life can be haha haha. We just spent $4000 on the rv batteries that i wanted this past year so I won't argue this one to hardYour wife is smarter than you, just like mine is smarter than me. Buy the cheap batteries, you can pay for two sets for the cost of the next ones up, warranty be damned, and 4 sets for the price of the Optimas. There isn't even a debate as to the right move.
