Issues with AC clutch on new system?
aztsm
AZ
2005 Ram SLT 2wd reg cab w/5.7
Had AC replaced over winter including dryer, compressor, and office line. I’m having issues when the clutch engages/disengages it makes a clacking noise, I can visibly see a jolt in one of the lines going from the compressor to the dryer, and it fluctuates my RPM. Took it back to where the work was done and they determined it wasn’t the AC but my belt tensioner. Well I had already replaced the tensioner and pulleys along with the belt just months before, and I replaced it again when I heard the noise thinking the same thing. So this time I purchased a mopar tensioner and new belt from mopar. The noise and symptoms continue. I really don’t think I’ve had the misfortune of 3 bad new belt tensioners and they verified the other pulleys were OK. Could my assumption over the AC compressor or clutch having an issue be correct? The dryer also made the noise that it typically makes after shutting off your truck after running AC, but it happened while running the truck with the AC on which I’ve never heard it so before. Opinions appreciated. None of the issues are present when the AC off. No issues idling or noises.
It's typical to hear the AC clutch engage and drop out, it could get more pronounced if the system is under load(as it gets hotter out).
If the refrigerant going through the system is making excessive noise, I'd suspect there a problem with the amount of refrigerant or a system restriction.
jws123
nj
Similar issue with a jeep 2 belt tensioners later the system was overcharged find someone with a set of guages and check it.
truck2569
Clay Center Kansas
Do you have the same noise when you turn on your defroster on your system that would tell you if it was the clutch or not.
paramax55
It could be overcharged. It also could have a bad fan clutch. That will cause high pressures and look like it's overcharged.
Sherman Bird
Houston, Texas
Some performance pressures at 1500 RPM and the blower on one of the high settings would be nice to help you... also the humidity and what the atmospheric air temp is.
