Issues with bilstein 5100
gibby252006
Can anyone call me and help me with my front shocks I got them mounted and can't get upper a arm bolt Help please!!!
ATOM
get a long pry bar and push the arm down into the knuckle. i had my cv pop apart when i did my bilsteins, talk about **** a guy off!
G
gibby252006
I been trying and the nut won't go on
ATOM
does the nut thread and just spin? or does the nut not even thread on the upper bj? usually you need to put a 10mm wrench on the bottom to thread it on
G
gibby252006
Getting mad all I have had was issues
ATOM
yea no ****, i would have bought a new truck already, lol. can you get the upper stud into the knuckle or not?
G
gibby252006
Think there would be a issue to drive it to a shop slow the nuts are on. But not fully seated?
ATOM
so the upper arm is in the knuckle if i follow you right but it's not fully tight?
ATOM
you need to put a 10 mm wrench on the stud of the ball joint and then tighten the nut up the rest of the way
G
gibby252006
About to take it to a shop and tell them to tighten for me. Can be more than 50.
ATOM
hmm that makes no sense, if it came out of there obviously it should go back in there. might when back in like a glove after i put in a new cv. can you get a pic? wish you was local i'd give you a hand! we will get this **** figured out!
ATOM
did you happen to crossthread the nut?
G
gibby252006
Bought new nuts. Where you at atom. I'm in Va
ATOM
wisconsin, i hope they were nyloc or you used loctite. so you got that sum'bich together then?
ATOM
do you have a pry bar to force the arm further down? or try jacking up the lower control arm? but if you do the latter be careful, that **** can get real damn quick. so can you get a 10mm on the bottom and a wrench it the rest of the way tight?
G
gibby252006
Nope. Tried most of that. I'm going to wake up an see what people will charge to tighten it. Over it lol
