mdifilippo
Hey guys,
So today I jacked up the truck and put it onto jack stands to pull all the wheels off. I look at the manual's diagram (which is SO detailed) and all over online. My 3 ton stands weren't tall enough to use on the frame to get the wheels high enough off the ground so I had to come up with another spot. Looking around every mentions the lower control arm. Great! I crawl under to look real quick and was a bit confused, I see where I could put the jack stand but not where I could use the floor jack to get it up at the same time.
Ended up using the cross member, right next to the protection plate jacked up from there and then put my jack stands under the control arm as close to the wheel as I could. Well it did great! No issues at all. I'm thinking about picking up 6 ton stands for the future so I can do the frame but just curious, IS this indeed an okay way to put the truck on stands for maintenance work?
