Dubstep Shep
- Aug 4, 2014
- 2,240
- 514
- Location
- Houston
- 2014 R/T
- 5.7L Hemi
Okay guys, I have a crazy plan, but it may just work.
Awhile back I was thinking to myself that it would be pretty cool if the Jeep SRT-8 Grand Cherokee brakes would work on our trucks. If you've never soon those brakes, they're massive.
I suspect that these calipers may bolt on to our truck spindles without any issues. The only problem is that I know the bolt pattern are different, so custom brake rotors would be required with the 5x5.5 pattern. That's not a big deal IMO, especially if the calipers fit.
Worst case scenerio and the calipers don't bolt up, I've been in contact with Michigan Metal Works and they said they could fabricate a custom spindle for me that is guaranteed to fit the Jeep brakes and whatever else I want it to do. I can pick up a set of these calipers for under a grand, so this is a MUCH cheaper option than the Baer or Rotora kits. Additionally I MAY be able to get the rear calipers to work with a little custom work.
Anyways, if any of you guys have the hookup on OEM parts or anything along those lines, I might be in the market for a few items.
ALSO: If you have a set of OEM spindles after you swapped to drop spindles, I WANT THEM!
