Jeep Wrangler
DILLIGAF
Canadian Forces
Canada
Wife is happy now, :waytogo:
They are a bit stiffer but way more comfortable if that makes sense.
I ripped off all the electronics on the factory seats and put them in these ones. No airbag light and didn't need to fiddle **** with resistors.
DILLIGAF
Canadian Forces
Canada
Got the new light's installed and adjusted. The dual fogs are cool AF . Turn on/off to select between Amber and White.
Obviously Alpha ODB to disable the DRL junk.
In the settings, you can actually enable the fogs for DRL.
Now I need to order some smoked out turn signal lenses. Don't like how they stick out now.
Didn't get flashed yesterday morning on my way to Edmonton at 5am, so the 36" high cutoff at 25ft works wonders.
Not bad for 150$ :driver:
DILLIGAF
Canadian Forces
Canada
That Ram is fire. :favorites13: Im partial to side dump exhaust :anitoof:
That Jeep is ******* perfect !
AleYeah
Greenville, SC
My daily driver for the past 10.5 years:
2014 Sport S with stick shift and 3.73 gears. AEV Savegre wheels wrapped in Toyo Open Country 35s. Cheapo Rough Country lift.
I had grand plans of overlanding with a rooftop tent and such, but my wife and kids are firmly entrenched in the "glamping" lifestyle- state park campgrounds with bath houses- so my Gobi rack is basically a glorified cargo box base (although it comes in handy for seasonal decorations).
Murphy Slaw
Southern Illinois
2016 Bighorn 4X4 Crew
I think we're going to buy one in Feb. or so.
I'm very curious about the little turbo 4 banger but don't see a lot of commentary about them.
Fatbob Frank
Mc Gregor, Iowa
6.4L
My one stipulation when we bought my wife's was I wanted the 3.6L Pentastar.
Supposedly this will be the last year you can get one with the automatic transmission.
Her Grand Cherokee 4XE had the 2.O turbo as it's powerplant and I thought it was pretty gutless on it's own unless you were nearing redline...
(Though the GC is heavier so it might be ok...)
But it was loud too, and the Wranglers tend to have less insulation and sound deadening so I figured it would be pretty obnoxious...
Murphy Slaw
Southern Illinois
I read that somewhere else, too.
Are they phasing out the Pentastar?
I've heard good things about them.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
3.6 isn't going anywhere any time soon. It's still the base engine for a lot of vehicles. And the new Ram Ramcharger will be using one for it's generator.
tjfdesmo
AZ
That's interesting, as I test drove a 4 door Rubicon in Prescott Valley, which is @ 5K elevation, and didn't find it doggy. It was only noisy when wound out, but so is the Pentastar when you put the spurs to it.
Fatbob Frank
Mc Gregor, Iowa
6.4L
I guess I just feel if you can get the same performance from a NA V6 why mess with a turbo at all...
By all accounts the new Hurricane S.O. 3L is supposed to out perform my 6.4L too, but I'm glad I got my Hemi...
I guess ultimately test drive one and if you like it buy it...
(I know they are discontinuing the ecodiesel Wrangler as well and lots of people liked those.)
I liked my 2009 Dodge Ram 5.7L
It only had a couple of Recalls
The Gas mileage was not the best
Then i bought the 2016 Ram 3.0L ecodiesel
except for the Federal Gov't spanking Ram & then the ECODIESEL SETTLEMENT
where the Gov't LOST
There was a time that it got 27 MPG when on a cross country trip
Then the Feds ruined that
Then recently, There has been a Recall on the Fuel Pump
which has been completed
tjfdesmo
AZ
But at elevation, where the NA engine will start wheezing, the turbski will stay much closer to its ratings. Even my 6.4 got pretty wheezy at only 5-8K feet.
Riccochet
They do need a new power plant for the Wrangler, and even the base 1500. The 3.6 Pentastar is getting a bit long in the tooth at 14-15 years old.
I'm for keeping it a lot simpler when it comes to the Wrangler. Turbo's are great, if you are moving, to keep the CAC cooled down. Off road, rock crawling, that thing is going to heat soak.
I'd prefer a larger N/A V6 or I6.
