Junkyard run questions
tzr916
Stockton, CA
14 QC SLT 6'4"
5.7L 8spd 2WD
Some day I may do a run to the local "pic-n-pull", for some stuff to put on my 2014 Quad Cab 2wd. I have alfaobd... have some questions:
1. Front chrome bumper (cover) with fog lights. Besides the fog brackets, do I need the full bumper underneath? or any brackets to fit my truck (that does not have fogs)? Can I also grab the fog wiring harness, and where does it run to? I'll be grabbing the headlight switch in the cab, does it require special harness/connector?
2. Power folding side mirrors (non-tow). The mirrors themselves, and the door panel controls/buttons. Anything else?
3. Dual exhaust and rear bumper with cutouts. Must I find a 2wd Quad Cab? Or does a dual exhaust from a crew cab fit on a quad cab? Does a dual exhaust from 4x4 fit on a 2wd? Do I need to cut any pipe and where to make the cut?
Thanks.
Ricks Ram
Thanks.
For the power fold mirrors you will need the door control modules for right and left doors,drivers door master switch and mirrors. Make sure the mirrors are off of a 2013 or newer Ram or you will get a check engine light and your outside temp will read-40° The outside temp sensor is on the arm of the driver side mirror on the 13 and newer Rams.
For the fig lights you will need the front bumper with fog light brackets,the fog light jumper harness and the light switch.
I have never tried to put the dual tipped 2WD exhaust on a 4WD or visa versa but I would assume they would be the same from the muffler back. You would also need to confirm bed length for fitment.
WilliamS
Tampa FL
Also if you have steel bumpers you dont need anything for the bumper, you will need the plastic inserts if there are any and full fog lamp brackets. Might as well hack a few inches of the harness from the truck side while your at it in case you decide to hardwire the fogs.
Exhaust is 2wd and 4wd, all you need to know is cab and bed length.
