Key Fob Gone - Programming a new key fob
DubyaC
Andalusia, Alabama
2014 Ram 2500 Limited - Push to start
So, my one and only key fob is gone. Truck is currently just a nice large brick until Sunday.
I have a key fob, OBD2 to RJ45 cable - RJ45 to Lightning Adapter that should be here sunday.
Truck also has a Ez Lynk Auto Agent 2.
Will I be able to program a key fob without being able to turn the truck to the " On " position? It doesn't seem so in the doc's I have read.
If I cannot turn the truck to the " On " position. Any advice?
Can't afford to take to dealer. Can't afford to have it towed.
I have done google searches, did a search on the forum before posting but I failed to find anything relevant.
jws123
nj
Not sure about your setup but using my autel km100 and or icon scanner from harbor freight I was able to program keys with all keys lost.However with a regular scan tool you will need to know your pin where as the autel it does it for you. If all fails have a mobile locksmith come out and do it for you instead of towing it somewhere.
D
DubyaC
Andalusia, Alabama
Okay, Well that is hopeful.
I am hoping I can do it with an App like AlphaOBD or Jscan or whatever variant. I am hard wiring into the OBD2 port, so I am hoping that works.
Thanks so much man.
jws123
nj
Thanks so much man.
as for your pin if you dont have it before i got my autel i used a android app called pin pull for chrysler.
Ken226
Washington State
In a 2014 both Alfa and Jscan can pull the pin.
Both can also program new FOBs, no prob.
Jscan can even do 5th gen. I did it recently with Jscan, In 2022 Durango RT with push button start. It showed as having 3 keys programmed, but only came with 1 from the dealer. I didn't like knowing that there were 2 more floating around out in the wild.
So, I deleted all keys from its memory, then reprogrammed the original and a used one from Ebay
Also, on a 2014 Ram, Xtool, Autel, ThinkCar and a few other scan tools can program Key fobs. Xtool can pull the pin, but I haven't tried it with the ThinkCar. I've been told that it can, but haven't needed to do it since I started using the ThinkCar tool.
When I try with the Innova 7111 it says "dealer only function", for both pulling the pin, and programming a fob.
D
DubyaC
Andalusia, Alabama
What I am really hoping for is that I can program it with a cable instead of needing a wireless adapter. :| Didn't order one but do have the OBD2 to RJ45 cable on the way with the adapter to my phone.
Can use the laptop if need be.
Ken226
Washington State
Im not familiar with any direct rj45 to OBD2 adapters, nor have I any idea what kind of programming or software might be needed to get a laptops Ethernet adapter to recognize and work with the OBD2 interface.
For a wired connection, some guys have used a OBD Link SX USB adapter with the Windows version of AlfaOBD.
If I'm remembering right, @RamDiver uses one. He'd be the guy to ask.
I seem to remember there being some kinda do's/dont's and setting tweaks, to get it to work.
RamDiver
Marlborough, Ontario Canada
2021 DS
Please post a link to this OBD2 to RJ45 cable, I'm curious. :cool:
AlfaOBD is designed to connect to a standard Bluetooth or USB device but it has a manual connection ability where you may be able to select com ports.
I'll check, next time I fire up the PC. I'm using the stupid phone ATM.
I use AlfaOBD for windoze with the OBDLink Sx that Ken linked. You have a great memory Ken.
The OBDLink Sx is fast and secure, and using the PC has many benefits such as easy management of backup files, screen captures and easy switching between different full-sized screens.
Also, following website directions or switching to your own notes or log files is simple.
For the windoze phobik, the OS is modified and performs only as directed. Microsoft has lost their ability to manipulate all of my PCs. :cool:
Anyone who is interested in reclaiming their PC or stupid phone ownership, please ask via PM because either type of device is simple to liberate. :cool:
As for special actions to connect, only the usual protocol used with AlfaOBD.
Connect the OBDLink to the OBD2 port, power up the PC, connect the USB, and then start AlfaOBD and click on connect.
Unless following this precise order, the connection process to your vehicle will usually fail.
The SOP for tweaking with AlfaOBD is to limit the number of changes per session.
This is a safe practice methodology that I usually employ especially when trying new or non-standard tweaks but sometimes... :cool:
Whenever the dealership has performed warranty work, had the battery disconnected and has re-flashed the BCM, I make several changes in one session.
LED configuration settings is performed in one session for low beam, high beam, CHMSL cargo lights, and reverse lights. I usually remove the fog light dropout with the LED tweaks.
Same for the DRL configurations and I have a few more tweaks with a Canadian truck.
RamDiver
2021 DS
My mistake about the Manual Connection options in AlfaOBD.
It allows a terminal function for reading/clearing faults, sending commands, and adjusting the OBD protocol format used.
The AlfaOBD Advanced Mode allows a manual selection of the interface type.
I have no experience tweaking these settings.
Dean2
Near Edmonton
Spot on, best advice you will get. One trick that sometimes works is to put the new FOB close to the start button and see if you can fool the vehicle into going into ACC or run.
If you need scan and programs for other stuff, worth buying, but for just doing a FOB, the mobile locksmith will be cheaper. Second point, use an OEM FOB direct from Mopar. 80% of the after market Amazon and clone crap won't pair and almost all of the ones that do, then kack within 6 months.
etbrown4
The guru on Ram fobs is Jimmy07.
Search and pm him, as he knows all
D
DubyaC
Andalusia, Alabama
Alright, several replies to get back to.
for OBD2 to RJ45 - Search on Amazon for that phrase.
Adapter - Search RJ45 to ( Whatever adapter ) I purchased a lightning one since I am a moron and thought since I couldn't turn the thing to the " On " position that I would need to hardwire.
:| Yep, hope some of your guys tips and tricks work as I am kinda out of work without my truck in which its about to go up for sale since I no longer need a 2500.
Ken226
Washington State
I just realized that when I answered your original question, I didn't explicitly state so and point out where but I assumed you would pick on on it.
But, back in post#7 I said: "So, I deleted all keys from its memory, then reprogrammed the original and a used one from Ebay."
If you deleted ALL the keys from the trucks memory, then it stands to reason that they won't work any more. So, they will no longer turn the truck on. So, in order to program the next fob, you will HAVE to do it with the truck switched off.
You don't need the truck switched on to program key fobs. It happens with the truck still in the OFF position. That is the case in both push button trucks and in tip start trucks.
Just buy a setup that is known to work. Trying all this weird, untested and unproven stuff is just begging for a tow truck fee to the dealer for a computer reflash!
metalchewy
Las Vegas
2010 TRX4
4.7L
To program a new fob with alfaobd you usually have to have an existing fob in the on position to start the procedure. I'm not sure it will work in your situation. You can try, but may need a dealer to do it.
Also, with the push to start feature in a 2014, you can remove the push button to expose the keyhole below it. The new fob can be inserted and switch to On.
I hope you can figure this out.
Procedure that worked for me.
Post in thread 'AlfaOBD programmed a replacement Key fob ok but it stopped working' https://www.ramforum.com/threads/al...ok-but-it-stopped-working.198291/post-2974291
Ken226
Washington State
After I read your post i went out to my truck to verify that my memory isn't failing.
I deleted my key fobs, then waited until the truck computers all turned off. Then I went back in and reprogrammed both of my key fobs
All without having a current, programmed fob and without ever switching the truck on.
Jacob Maguire
Pine Beach NJ
Hemi5.7
If you get past the link/adapter issues and establish a connection with Alpha or JScan, be sure the replacement FOB is of decent caliber. I've attempted to code and failed using a cheaper amazon FOB. After ordering the linked to FOB as the second replacement, JScan was able to successfully code the new key, error free.
EClare
diesel
I know this isn't what you're wanting, but I bought my '18 3500 used with only one fob, the kind that looks like a flash drive. Just to have an extra, I had locksmith make me an old school key for about $80, which I keep in my purse. Don't go to the stealership.
EClare
RWlRAM
SoCal
1994 4X4 - Replaced 12-31-17 with '04 1500 4X4
5.7 Hemi.....wow what a difference 10 years makes.....
Sorry but I can't seem to figure out how to PM here but interested in reclaiming my WIN 7 Pro setup......Thanks RW
