Key Fob
dw1970
Metamora IL
Hello. I just purchased at 2017 Tradesman. It did not come with Key Fobs. It just came with a pair of keys. I purchased a pair of aftermarket key fobs and used AlphaObd to pair the key fob to the truck using the instructions on this site. The key fob now starts the truck just fine.
My question is about the lock and unlock function on the key fob. When pairing the key fob using the RFhub in Alpha, was it supposed to activate the lock/unlock functions on the fob or is that a setting in the BCM. The truck does have power locks and windows.
Any help you can give me would be great.
Dudro612
Did you reset the RF Hub? It should work the unlock/lock.
I have a 2015 tradesman and once I paired the keys and reset the hub the lock/unlock worked.
I'm surprised the remote start worked you didn't have to turn it on with Alfa OBD?
Let us know the steps you went through and maybe we can see what you missed.
D
dw1970
Metamora IL
Here are the steps I took:
Choose the following from Alpha:
RAM 1500
Radio Frequency HUB(RFH)
Radio Frequency hub
Then I connected to the RFH
Pressed the car hood button at the bottom
Program Ignition FOBIXs Baseline system (with the new keyfob inserted)
Started the program after entering my PIN
said it was successfully paired
Used keyfob in the ignition and it started the truck fine.
I had not reset the hub so I will try that next
Thanks for answering so fast
Dudro612
I remember what you need to do after reading what you did. You have to change VehConfig 3- RKE system to present then reset the RF Hub. That will fix the issue.
Here is a link to add the sales code GXM to turn on RKE system.
Athlium
Tacoma, WA
3.0L EcoDiesel
I'm in the same situation but with a 2018.. looking for fobs as well.. which ones did you get?
Athlium
Tacoma, WA
3.0L EcoDiesel
I forgot that I got these a while back.. and was able to program them to get them to work today
Should have looked more.. got a set for less and remote start as well.. (yes... I am aware that remote start will require additional hardware)
johnsmith69
3.0 eco diesel
What software did you use to program the key fobs. Having the same issue with my 2016 tradesman
Athlium
Tacoma, WA
3.0L EcoDiesel
AlfaOBD for android and Windows PC. You will also need a OBD reader, I believe most people use OBDlink MX.
Jwithing
STL
Anybody know if you can program new, full keyless ignition fobs with the alfaobd or does it only work with the nub style fob that sticks into the ignition port?
Gordo2212
Mississippi
2018 3500 Tradesman
6.4 L Hemi
Shouldn't be any different to program the keyless fob vice the turn key fob.
Athlium
Tacoma, WA
3.0L EcoDiesel
For Full Keyless ignition fobs, you would choose the Highline system.
johnsmith69
3.0 eco diesel
I used alpha obd2 and MX plus to program mine. Worked perfectly
rramb
Gurley, AL
I have a 2017 tradesman with the manual key as no push button start with different results. I have tried the above processes w/mx+ and full version of alphaodd but nothing works. My key fobs look like Ram factory keys. A locksmith told me trucks with manual keyed door locks are not equipped to support key fobs. My Ram dealer stated my truck wasn’t equipped as well. I’m not going to give up just yet. Besides trying a different key fob, does anyone have any suggestions?
