L Headlight out again?
jljbtm
I've replaced this bulb twice in a year now. anyone else have this problem? 2011 V8
Sent from my SM-N950U using Tapatalk
Wahrsuul
Central S.C.
Are you sure it's the bulb? My 09 had an issue with the connectors. Pulled them out, slightly twisted the flat pins and haven't had an issue since.
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Also, what brand and model of light are you using. Those ultra white bulbs tend to have a way shorter lifespan. I went through a set almost every 6 months in my wifes car until I just went back down to a standard long life bulb.
Maine
Yes I also have a 2011 Laramie and the right light get progressively dimmer in a matter of 2 months or so and I have to replace it ... I have been using the 55k hid knock offs from Ebay but thinking about getting something better from the local auto parts store.
These are the quad lights and I have cleaned and checked for loose connectors..... seriously looking at aftermarket projector headlights.
Wahrsuul
Central S.C.
Don't use HIDs in halogen housings. Unless you just enjoy blinding everyone. And cheap HIDs are usually cheap for a reason.
Go with projectors, or just the higher wattage halogens. There are also some good inexpensive LED replacements for the halogen housings.
Maine
Yeah sorry, to clarify ...
They are halogen xenon bulbs. "HID" like ... because I am cheap
Maine
Like these beauties
Hootbro
U.S. Army Veteran
Army
Delaware
Pentastar 3.6L
Those obscure name Ebay specials are many times a pig in a poke. I have had short life with them the few times I have used them in another vehicle.
Better off spending the extra coin for Sylvania or Phillips branded bulbs for better results.
Mack1207
Bryan, TX
Those obscure name Ebay specials are many times a pig in a poke. I have had short life with them the few times I have used them in other vehicle.
I agree. If putting in a solid light bulb still gives you issues (since it sounds like it is only one side) check the power draw. It may be a short causing it to fry.
