Lamp out problem
DBrown21
Magnum 3.7
Every single time I take my truck through the car wash the lamp out light pops up on my dash and usually goes away after a couple minutes, but this time it's on for good. So I checked all the lights and it's my right rear tail light works, but it doesn't get brighter when the brakes are applied like the other lights do. The bulb is on, just doesnt get brighter like it is suppose to when the beaked are on. Anyone had a similar problem and fixed it?
Stangshcky12
Oshkosh, WI
5.9 Cummins
Behind the tail lighT is a white housing that is basically a circuit board
They are known to go bad (especially the passenger side)
I have an extra one but it would probably be cheaper for to buy a new one (I can't gaurs tee it works perfectly either)
I think they are about $15-$25
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Yep replace the board. My turn sigles would blow on mine, after the second replacement bulb I put in I changed the board.
DBrown21
DBrown21
Magnum 3.7
Thanks. I'll replace the board then.
Raadz
